15" wheels for Pinto
O.K. so we can use 15" wheels if we had 13x6 wheel with a p205/60r13 sec width 8.0" diameter 22.8" on a Pinto. What are you guys going to do? Mustang gt wheels 15x7 4on4.25 as I remember,so can we use those or do we have to have a 15x6" wheels then what tire do we use or 14x6" HELP I am I the dark right now Thanks Glenn
How about a 14?
205-55X14 gives you the diameter you seek.
Cheers.
Since 74/80 Pintos have better brakes than 90% of the cars in IT-B, what will you gain over 13" wheels? As long as 13" tires are there to buy, why change? Stiffer side walls (at the same dia) are the only plus.
Dick I was fishin for a response from you, plus you add more un-sprung weight too...
Thanks Glenn
GLENN! Brakes might run cooler too, but that has never been a problem on my cars ( I'm always in a vacuum in the back anyway)Do what I do, and buy the rears off the Speckle/Fords. Later, DICK.
If enough is ok, more is better,and too much is just right.
