2002 front end pushes
I just bought a 1976 02. I will be using it for the street for now but wanted some advice and know this is where to get it. When I corner hard and fast the front end has a tendency to push and slide the front wheels before the rear gets loose. The front end is a little loose, needs a center link and ... so while I am at it what would you suggest I try to keep it pointed in the right direction. Is it also a matter of driving style? It has Bilstien Sports, not sure about the spring rates or the size of the sway bar.
