I am in the market for a compressor that can handle all auto tools - including autobody tools. This is for personal use, not business, so I want to stay under $450.
Looking for suggestions/comments on either of the following two compressors:
HUSKY
7 Peak HP 60 Gal Husky Compressor
Model VT6314
A solid CAST IRON, twin cylinder compressor pump for extreme durability. Offers 135 PSI maximum pressure and air delivery 11.7/10.3 SCFM @ 40/90 PSI. It also has a space saving vertical design that is perfect for your home garage or work shop. The compressor also includes an efficient Solberg style intake filter, pre-plumbed globe valve, pressure switch, and tank pressure gauge.
• Up to 5,000 hours of extended life
• A CAST IRON oil-lubricated pump with traditional design that is quieter and longer lasting
• 60 Gallon vertical, space saving tank design
• Powerful, 7.0-peak horsepower motor provides significant air to multiple power tools
• Automotive style changeable air filter
• Protective belt guard
• High quality oversized gauges
• 1070 Pump RPM
• Three-year limited warranty
• Over 35 percent quieter and 60 degrees cooler than aluminum pumps with cast iron sleeves
http://imagex.homedepot.com/f/248/13...64587314_3.jpg
Lowes
http://images.lowes.com/product/8405...d=158&cvt=jpeg
They seem to be very similar.
Jason
ITB 17 (NER SCCA)
VW Scirocco
[This message has been edited by itracer (edited June 17, 2005).]
