Originally posted by spsspeed:
Louis,
Depending on which VTEC car it is for there are different options.
For the 94-95 GSR you are pretty limited in choices, AJ Racing in Canada will re-map the fuel and timing curves for a small fee. All you have to do is send them a dyno plot of your car and the corresponding A/F ratio.
Also Anthony Serra sells a modified computer for the GSR, he is out of NY. I know a couple people that are using his program.
My guess is that you will only gain 4-5 hp somewhere in the power range.
Other car like the Del Sol VTEC, newer 99 Civic SI and the 92-93 GSR have alot of options since they do not have the dual intake manifold.
I don't think changing the VTEC crossover point will help since it is at 4350rpm (for the 94-95 GSR) anyways so the car is always on the high end cams during a race.
Hope this helps. Which car are you going to get?
I will agree with Rich that for the CRX you are exremely limited. All you can do is check your A/F ratio with a wide-band O2 sensor, if you are OK then all you could do is re-map the timing curve.
Scott Seck
#38 ITS GSR
