Completing ITA car and found a couple of the rear wheel studs had been tack welded to axle flange. Wondered if we should have the new studs tack welded also? Is this reccomended to do?
Be interested to what others who are better wrenches than I say, but I just use the medium strength loctite...never had an issue in 9 years.
I recommend the screw in studs from MazComp. LocTight is the best method, especially if you toast a rotor and want to change them out.
Frank
#67 IT-7
SE-Div
www.balz.myip.org
