camber in 88 crx
I'm looking to dial in some camber on my crx, and wondering what kind of camber kits are recommended for the crx. I know there is adjustable rear upper control arms, but I can't find adjustable front upper control arms, except for Cusco and Vision units that are only available in Japan.
Are concentric bushings any good?
What are recommended camber settings?
Thanks...
I'd like to know, too, especially with all this talk about spherical bearings/modfiying control arms.
I slotted my upper controls arms, but I don't know that it would pass tech at an SCCA event.
J
I guess everyone is driving around with negative camber, then...
You've probably got about one and a half degrees in the front on your car. I ended up with around two and three-eights at the end of last season, it did make a difference.
Funny, no-one wants to talk about it, huh? I wonder how they all do it? I asked a guy (King motorsports associated, I think) at Road America, once, and he shooed me away from his car, saying, "we found a way.."
I don't have my car to look at right now, but do you think it would be possible to somehow set up something like a camber plate, where there is slots running perpendicular to the car, allowing the UCA upper mounting points to be moved inward and outward to adjust camber? This would not change the control arm itself, and the rules state that camber plates can be used. Would changing the upper mounting point of the UCA affect anything else, maybe caster?
What do you think of this idea? Maybe there isn't even room in the wheel well to slot the mount points, who knows
what is your ride hight if it is 22.5" fender lip to ground you should have 2.75 to 3.0 degrees neg camber the higher your car the less camber if you don't have that much your upright is bent use the eccentrics to adjust they work well
The way the "body" is re-inforced at the UCA mount, it definitely precludes any sort of slotting at the bolts. That's the problem. That said, any of the commonly availiable camber "correction" kits accomplish exactly what you say, but in a way that's diffucult to explain.
I didn't buy one of these kits because they are overpriced, in my opinion. Slotting the holes in the upper arm works, doesn't cost anything, and meets the intent of the rules, if not the exact wording. Same for camber correction kits.
The exact wording of the WCMA rules is a little strange, because REAR suspension holes can be slotted for camber adjustment, in the case of independant rear suspension.
Oh, BTW, Showroom stock racers have been known to "bend", accidentally, of course, the hub carrier..... with an oxy/acetylene torch.... http://Forums.ImprovedTouring.com/it/redface.gif)
Jon
OK, I checked my GCR, the wording is the same as WCMA....
"On other forms of suspension, camber adjustment may be acheived by the use of shims and/or eccenric bushings."
You could get into some pretty long arguments over this one, get out the dictionaries and battle about the definition of eccentric bushings, cause the commonly availiable adjustment kits are not actually eccentric. Same goes for slotting holes in the control arm.
I'd REALLY like to hear how the font runners are doing this.... ANYONE?
Of course, you could slot the holes, and not mention it. It's REALLY hard to see.
Jon
mr nelson could you explain how its legal to slot the upper a arms the IT rules seem pretty clear on this
It's NOT!!!! According to the way the rules are written... but then, niether are the commonly availiable camber correction kits, ie Ingalls.
So, what IS legal? How does everyone do it?
Jon
mr nelson when i said use the eccentrics i was talking about specialty products eccentic bushing not slotted eccentrics they make and like i said earlier ride hight is very important
mr nelson what is your ride height
Concerning ride height, unless you have a very smooth track to run at (not like the midwest tracks), if you lower your car enough to get near the minimum allowed ride height, you will be lacking suspension travel, especially with Hondas.
My car is about 3/4" higher than the legal minumum (5 inches), with 205/55-14 Kuhmo's, and I got about 1.5 deg neg camber before I slotted the holes (highly illegal, BTW, but I wasn't running SCCA).
Of course, there's the option of shortened struts....$$$$$
JOn
you need to lower your shocks 1" in the saddle don't use the stock divit on the shock
Good idea!! I did this in a different way, I added about 3/4" to the upper shock mount, to increase travel by basically moving the bump stop UP in relation to the body. I THINK this is legal.
Still leaves confusion with the camber....
mr nelson call me 310-370-0950 bernardo
What about? I think we're on the same page, but I still want to hear from others about the whole camber thing.
I SUPPOSE it would be possible to make some truly eccentric bushings, fit them to the stock pieces, etc. but of course it's a slippery slope to slide, especially if you've been following the whole spherical bearing argument going on elsewhere on the forum.
So, who's got eccentric, legal, %100 comp board usa approved bushing kits for sale?
j
i'm unclear on your spacer placement you may have lost camber with it i'll get you the part # of legal bushes
My solution is the same as yours, it's just being done at the other end of the shock assembly. No effect on the camber.
If you like, you could E-mail he manufacturer and part # of these bushings.
Jon
mr nelson part specialty products front part #84700 rear part #84580 call the PROGRESS GROUP 1-800-905-6687
