Is anyone using Koni 2816/2817 struts? They seem to be the only rebuildable and double adjustable non-canister inverted strut on the market.
Do you have any information on the struts? I am specifically interested in the top pin dimensions.
I have a hard copy of the manual which is at the office, I am sure there is an electronic version available. I will ping the guy I bought the car from.
Derek
Metic Unit Manual
English Unit Manual
These are them.
Thanks for the links and info. I already looked at them.
Unfortunately Koni has conflicting information on the strut top pin dimensions. The dimensions range from M16x1.5 to M18x1.5 to 3/4". I sent an inquiry to Lee Grimes @ Koni asking for details of the top pin options. The top pin is welded to the damper tube so there are some options (potentially). I prefer the M18x1.5 as this is used on the Bilsteins and match my camber plates (i.e. no bushings on the spherical).
I wanted to see what current 2816/2817 struts had for a top pin.
THE best struts would be a linear roller bearing strut with any standard damper guts. Penske sells them @ $6k per strut. Proflex and BOS offer them, but I don't know their prices. Definately NOT in the IT budget.
