Mine's still in the car. As part of the offseason weight reduction plan, I assumed you could take it out and started to, but then checked the rules. Didn't see anything.
THoughts?
THoughts?
I don't think so. I left mine in until it became an STL car.
Mine's in the car too but I have to add over 200lbs in ballast.
Having said that, I like the noise reduction and water seals that come with it. I know you are searching for ounces to turn into pounds but I like it in there.
that's what it looked like to me.
I read 9f under 9.1.3 saying I can remove them. They weighed nothing but were poorly reinstalled once on my car after a poor removal and were falling off.
Its a cleanliness thing for me. I need plenty of weight. I left the plastic clips incase I get protested.
I believe them to be insulating for the interior trim
Hoo boy. Here we go again...
hahaha
PROTEST ME. (or please don't I'm new to this)
"carpets, center consoles, floor mats, headliners, sun roof liner and frame, dome lights, grab handles, and their insulating , attaching, or operating mechanisms may be removed"
"all other interior trim panels except the dashboard may be removed"
gravity was removing them already. I just helped them along
I was completely kidding sir......haha
if ya'll seriously think its a problem I'm 100% heading to a junkyard to properly pull off weatherstrip so it won't be falling off and pinched between the door and rocker making the door tough to open....lol
that really was the reason I yanked it... I thought it was accepted too, from looking at other cars
I bought a car that was a cosmetic mess, and had been driven hard and put away wet. The cage ans drivetrain were all it had going for it. I like decent looking cars and tidy looking stuff, so after updating the cage a bit, I started making it look like less of a circle track throw away and more of a picture worthy car I can be proud of.
building a "rule pusher" isn't my goal at all, in any way
Ha, don't look at other cars to see what's legal, look at the rulebook and decide for yourself with your reasoning and go from there. Most modifications like this in the paddock are done with 'convenience' and 'it's nothing that makes me go faster' as the 'reason'. Not because anyone actually thinks it's legal.
ONe time, in band camp....
back when I ran in ITA, my lil ole RX-7 was getting it's ass whipped by the likes of Blaney and Serra, etc. We had an impound all. I finished a whopping 5th, I think, and it was "hoods up". Tech guy comes over, and tells me the two 6" long rubber seals located at the back corners of my hood were mia and needed replacing before the next race. Easy to do cuz they were in my garage and never got snapped back on in the rush after a full paint job. But that pretty much reinforced for me that all seals must be there.
I was impressed he even spotted them missing! I figured I fell into the "nobody gives a crap about that car " crowd, LOL.
awwwwwww MAN.
I can never find time to go to the junkyard. Stupid real life jobs. Haha
thanks Jake
everyone else agree?
Adam,
what are you missing? i might have some stuff on my HF POS i am parting out....
The perimeter door weatherstripping and hatch perimeter weatherstripping
FYI.
i am not a big fan of rules that say "etc." (my emphasis.) and then we try discern what that etc means...
from page 113 of 7842 in the 2012 GCR
In Improved Touring, Showroom Stock, Spec Miata, and Touring the door window glass, window operating mechanism, inner door trim panel, armrest, map pockets, wiring harnesses for door locks, windows, power mirrors, seat wiring, etc., and inside door latch/lock operating mechanism may be removed and the inner door structural panel may be modified, but not removed only if the door bars extend into the door cavity.
I agree. My preference is to write a rule to say what you mean, then use "e.g." to provide non-limiting examples. "Etc" leaves a big hole to drive through. In this case:
NASCAR-style side protection or one bar bisecting another to form an “X” is permitted. Door side tubes may extend into the front door. To facilitate installation of these door side tubes into the door, Improved Touring, Showroom Stock, Spec Miata, and Touring may remove interfering items, e.g., the door window glass, window operating mechanism, inner door trim panel, armrest, map pockets, wiring harnesses for door locks, windows, power mirrors, seat wiring, and inside door latch/lock operating mechanism; the inner door structural panel may be modified, but not removed, only if the door bars extend into the door cavity.
In the real world.. most anything that burns can be removed and pass tech, and fellow racer tech. IMHO.
I left my rubber seals in for the IT cars.
The cage door bar rule is not followed at all either.
I hammered,slotted,etc the OE inner panels, for years to meet the letter of the rule . Now I just X brace the pas side and toss the inner panel, as does the rest of the world. Time to fix the rule wording .
IMHO.
"Nobody" leaves the inner panel in today.
My bars both extend ALL THE WAY on both sides now, basically touching the factory crush beam in the door. I re installed the outer stripping around the window, i had only removed that "inner" gasket strip. The certainly can burn. Im not likely to win anything anyways so maybe ill leave it. Haha
Ah... yeah, let's not generalize. I have the passenger inner panel of my door installed because I have an X bar and decided not to put in an alum metal cover.
Some racers do try to follow the rules with integrity no matter how annoying and even if some others purposefully choose not to.
It all depends on your min weight.... A window motor low in the right door is a great place to leave weight if you are underweight...
I dont see many pas doors with the panel beat into the hole, so that the nascar bars can fit, per rules.
FWIW my new SM has both electric mirrors working.
Making a big deal out of 25yr old rubber door seals is as counterproductive as the heat shield discussion . IMHO.
The car may go faster with all of the seals, less sq in of contact to air.
Back to my hole. sorry . MM
" modified but not removed"
For M.O., from Roll cgaes for GT and production based cars:
means the inner metal structure has to be there in some form. you can cut chunks out of it, but you can't just gut the whole thing. you certainly don't have to beat the panel to accomplish fitment.Quote:
Originally Posted by GCR
Yea, the compliant thing to do if you are looking to shed pounds is to remove the panel and door innards, leaving a 1/2" or so section of the panels perimeter. Put door opening welting on that raw edge for protection. ...........then make sure at least ONE bar enters the door cavity to some minimal degree. And thats it, rule met. You CAN build huge structures on that side, but id you're trying to make weight, thats a bad idea.
But just so we understand, the rule allows nearly complete door gutting IF a SINGLE horizontal bar protrudes into the cavity.
This is the evolution of the rule. This rule was changed around 1994 or so. I built cars before and after that(50+cars). The first year, the tech guys said to slice the panel and pound the panel clear of the door bars. We ( builders ) said that was stupid, he said that was the rule,live with it.
The next year many of the cars had the panel cut away, as they are now, just leaving the edge with a hint of the panel plane.
The same( FLR) tech guy said that we were all illegal. WE said that if we all went home, so could he. ( And the cut out panel became the norm around 1995.)
Now days the car have the panels cut out, both sides. Often the pas side have the stronger,lighter, short straight bars. With no door panel intrusion.
The rule has changed but the old wording has stayed. IMHO.
No place else in the GCR does" modify" equal remove large parts of.
Not really an issue IMHO. Look around at the SM cars. Those guys cut everything and no body cares.
The regs may require two bars, but the glossary defines nascar bars as "one or more" bars which protrude into the door cavity.
So, ergo, only one of the two required bars is required to break the plane that defines the door cavity.
I think the rule was written that way to encourage people to use the space within the door for added protection, and to give as much flexibility to existing situations.
On my car, i made a set up that had a door bar meet the internal door beam, and the vertical sections transferred down to a lower bar that was a bit inboard. I decided to use the space based on wanting to keep the offending T bone car as far from me as possible. But on the passenger side, I bust broke into the cavity, and used a modified X pattern. I wanted lighter weight, increased chassis strength/stiffness gains and crumple space for lower Gs if there is a T bone on that side.
My X barely entered the cavity.
Sadly you are right, rules interpretations evolve and worse local tech inspectors sometimes do not interpret as intended. This of course is the very hard challenge of writing clear rules.
For instance recently we found that in two divisions it was interpreted that FIA seats need back braces when they get old. The tech department and CRB disagreed and it has been clarified that for SCCA this is not true. Sadly the club made things more difficult that it needed to be for competitors in those areas for years.
One of this internet board’s biggest value is to vet these interpretation difference and build a consensus as to what the rules mean.
This likely stems from NASA regs, which initially interpreted it that way, then explicitly require back braces after five years. I ran across this last time I raced with NASA (almost got sent home) and has been the primary technical reason I have not raced with them in five years (I refuse to modify my FIA-certified seat to add a back brace).
As you know, Dick, this is something that scrutineering circles discussed internally and chose to disregard, but I like that we're explicitly codifying it in the GCR.
GA
I have a customer car here now for the FAI seat brace.
I was told the same thing by tech/owner. Over 5 or 10yrs old( second hand info). The seat needs a brace.
What is the actual rule? The seats are not designed for any structure up near the shoulders IMHo as they flex a bit and are quit thin.
I can understand some sort of "back stop" rule, to keep the driver from loosening the belts in a rear hit. The back stop should be at or just under the shoulders, well under the neck/head impact area IMHO.
I dont want to drill the shoulder area without adding a lot of glass/plate to spread the load. In carbon/glass structure, that can lead to other failure points by increasing the strength in one spot . I dont want to do a LPA for modifying a seat.
TIA, MM
9.3.41. SEATS
The driver’s seat shall be a one-piece bucket-type seat and shall be securely mounted. The back of the seat shall be firmly attached to the main roll hoop, or its cross bracing, so as to provide aft and lateral support. Seats that have been homologated to and mounted in accordance with FIA standard 8855-1999, or seats that have been certified to FIA. Standard.8862-2009 or higher need not have the seat back attached to the roll structure.
Note it now says “Seats that have been homologated”. This should clear up an confusion on expired certifications in SCCA at least.
If I was adding a back brace for some other sanctioning body I would never drill a composite seat. I would bond something to it. Double stick tape might work.
