http://www.scca.com/documents/Fastra...strack-apr.pdf
Thanks Andy.
ITR V8s and RX8 still under review?
Gotcha. I told Josh S this, I finally (my apologies to Earl and Josh) have the revised ITR spreadsheet done. Will get that to you this weekend after I fill in the last couple of my blocks.
Sorry about the delay, work has been nuts.
thanks again for the hard work.
no mention of RR damper allowance when originally equipped?.... not even tabled for review?
Dan, I will do that. Remind me again over the weekend if I forget.
Jeff
I'm not sure why that didn't get a mention...it's getting "heavy airplay" over on the ITAC site. We meet again this coming Monday, I imagine there should be a response forthcoming.
If I read the rules correctly, cars so equipped from the factory MAY change their dampers to units that are non RR, with a max of 2 adjustments. Which means that the OEM units may stay.
IT Allow alternate fuel injectors (Ellis-Brown). IT requires stock injectors.
That's a make sense request to me. Nice smart a** reply stating the obvious. You can change fuel with an FPR and ECU but you can't change injectors? Umm, okay.
VW Mk IV Golf to ITB @ 2350#. Would seem to make sense, as it's the same layout/drivetrain as the Mk III, which is spec'd @ 2350#. But, the Mk IV starts w/ ~260# more, based on curb weights listed on Edmunds (2771# for the Mk IV, 2511# for the Mk III, both 2dr GL models). Take off another 300# (180# for driver, 120# for cage), and you need to get that Mk IV down to ~2050#. That's over 700# off the curb weight (over 25% of the cars curb weight). Wow.
That would actually be great idea Andy. Many times I think people come away thinking their items haven't received any attention and just got no, because I said so respone when in reality you guys have spent time discussing it. It doesn't have to be anything lengthy but it would demonstrate that various items were considered.
Andy,
I would have to concur. The printed answers to items 1, 2 and 4 seem rather curt and dismissive.
Item 1. Is asking for a rule change and the cited reason for denying the request to change the rule is the rule itself.
Item 2. Asking for a change in the rule not a clarification of the rule. The cited reason makes it sound like someone is asking for the placement of a comma to create a subordinate clause.
Item 4. The cited reason may leave the impression that the weight was not even reviewed.
Just MO.
I am not sure what we can get through but I was thinking something like this: New in bold
1. IT Allow alternate fuel injectors (Ellis-Brown). Thank you for your input. The committees do not see a need for this allowance at this time.
2. IT Allow ballast in place of the spare tire (Greene). Thank you for your input. The committees feel the current ballast rules are adequet as written.
3. ITB Allow alternate gear ratios for the Jetta (Ellis-Brown). Thank you for your input, however no new data has been presented to support the request.
4. ITS Review the weight of the 1972 Porsche 911E (Allard). Thank you for your input. The car is weighted appropriately in ITS per the classification process.
I know that the 'thank you's' will become almost disingenuous to some but just a few more words could help. Anyone need more than this or am I missing the mark completely?
I think you hit the mark dead nuts.
+1... though does anyone out there really think it is even consistent with class philosophy to allow alternate fuel injectors? Maybe I'm missing something, or there's more detail to the request than I'm aware? Sounds (on the face of it) to me like someone wants to run bigger fuel injectors?? Or is it that stock injectors are no longer available??
I personally don't need bigger injectors, but if you can already control flow with the ECU and an/or FPR, why is it a big deal to allow different injectors? Maybe it's more complicated than the average mechanic understands as Steve hinted to. Would opening up injectors give any car an advantage that couldn't already be achieved with the current rules? Geez, people are talking about RR shocks right now and standalones are legal, injectors are nothing compared to those.
+1 Andy has the right idea on appropriate responses.
if you up the fuel pressure your weakest link is still the injector. You can only flow as much fuel as the injector will ultimately allow. Open that up and watch the carb guys scream. Hell, I'm a FI guy and I might have to scream about that one. In a few cases bigger injectors = more power.
I agree with everyone else on the responses to request and how they are posted.
Sadly but I actually think there may have been more to that. The person may have one of the pesky cars with high impedance injectors but the cheaper ECUs want low impedance injectors. Its not an issue per se, but its an annoying need for a work around.
I seem to be having some formatting issues!
Below is the original request: Seems to be asking for equality between carbs and FI...YMMV.
Rule Change Request
Under item D. Background and current wording,
1a. Reciprocating Engines (only) reads -- Any carburetor jets, needles, and/or metering rods may be used in the stock or approved optional carburetor(s). Alternate needle valves are permitted. Removable jets may be replaced or resized.
Carburetors have not been used on American marketed automobiles since the late 80s or early 90s. Fuel Injection systems replaced them and some configuration of fuel Injection is now the standard on American marketed cars. The "inner components" of Fuel injectors contain a combination of jets, needles and metering rods that were part of carburetors.
I request that the CRB consider the following changes in order to update the ITCS by incorporating similar / existing language as written in the 2008 ITCS to better reflect the current complement of automobiles that are now included.
Therefore I would like to propose a change to the current ITCS to permit the replacement of fuel injectors on fuel injected vehicles. I submit 2 alternative rule changes to the CRB. To add an item 8 to read:
8. On fuel injected cars it is permitted to replace the fuel injectors as long as no modification is made to the mounting surfaces or inserts of the cylinder head and the stock fuel rail is retained.
OR, to amend item 6 to include
6. . Fuel injectors maybe substituted as long as no modification is made to the mounting surfaces or inserts of the cylinder head and the stock fuel rail is retained.
With the most recent changes to the ITCS, specifically the addition of items 6 and 7. on page 331 of the GCR, I believe that this request is within line of the CRBs philosophy of permitting the upgrading of the Engine Management Computer and the addition of needed / required sensors. I also firmly believe that this change will not add any additional cost or rules creep that is beyond the current thinking of the CRB and the ITCS. I can make myself available at any time to further discuss these change requests and necessary.
Or someone with mechanical injection could use the rule to go to electronic and make it work with the opened up ECU and wiring.;) Now you have some serious changes in that classes parity.
There are several reasons that the writer might want different injectors....perhaps he actually is rich at certain points, lean at others, and the combination of higher pressure and smaller injectors yields more power. Or vice versa.
To your other points.Actually, you should say "Standalones have been legal for years now", assuming you are talking about ECUs. Keep in mind the Process and weighting of the cars was done post open ECU rule.Quote:
"Standalones are legal now."
Which leads to the next point. Cars are classed based on stock hp and a process. The stock HP is made with stock injectors. To now open up injectors would change the balance that exists. Good idea? I think not.
Your RR shock comment is, to my eye, not comparable. First, there is no rule change or proposal regarding RR shocks on the table. Second, people more knowledgeable that I can tell you that RR shocks are not the savior, and won't have seconds off your lap times, no matter how bright you are, compared with monotube or twintube designs. There is a perception that they are the magic bling item that shaves seconds, but that's just it, a perception.
I disagree with the comparison in terms of degree, but mostly because any shock rule would affect all cars more or less evenly while an injector change would not. Any such change would be equivalent to a post classification competition adjustment.
Ummm... hang on. I didn't notice this immediately, had to be pointed out... The Mk3 Golf is a single-cam 2.0L, right? But, according to the classification, this is a DOHC 2.0L? Sounds more like an ITA car, to me, than an ITB car. At least at that weight. Bigger brakes than the Mk3 also - doesn't concern me as much, but worth noting...
Doesn't sound like the same car anymore... Did we just move the target?
Vaughan,
The Mk IV car has an SOHC motor, not a DOHC motor. VW hasn't offered the DOHC 2.0 since the late A2 Golf/Jetta and the B3/B4 Passats. I didn't catch the issue about the larger brakes.
The reason I posted this, was as a result of the discussion around the Protege landing in ITC. One of the main reasons put forth for it going to C and not B, was it's ability to make the B process weight. It was pretty much the same argument that was used for the New Beetle (which has a curb weight of maybe 50-60# more than the Mk IV Golf). I just don't know how you'll make the ITB process weight w/ a Mk IV Golf. 700# is a lot to get out of a car that starts out at <2800#.
Sometimes I make an ass of myself, here we go.
Current IT rule set says fuel pressure regulators are free as are resistors and sensors.
So why would you lose the protest over having changed your fuel injectors? They are a part of the pressure regulating system....
OK, cool, thanks for the clarification. I'm definitely no VW expert, just have to go by what's in the book - which is apparently already in need of correction, 'cause it does state DOHC! :blink:
I'm not so sure that larger brakes are so much of a big deal - are the Mk3's so limited in braking? Either way, based on what you've pointed out about the weight, may be a moot point?
As for pressure regulation - is it really reasonable to try to claim that the fuel injectors are part of the pressure regulation system? Put it that way - so's my CIS fuel distributor, so I can replace the whole thing. Good luck with that argument! ;) (but hey, no complaints about playing devil's advocate)
Funny, I don't see it as a new paradigm so much as I see the intArweb as a vehicle to see how more people 'read' the rulebook. Which is to say I don't think the 'thinking' has changed, just how much you know about other peoples thinking.
brake fluid burns but not real well so it could be a fuel. and fuel pressure regulators are free.
ii think your tilton set-up works on several levels. it is always nice to have spares at the track. spare rules are a good idea as well.
Injectors are rated based on the volume they flow at give pressures. Aren't they volume regulators, rather than pressure regulators?
I feel bad that I didn't notice the "DOHC" thing in the specs that the ITAC was provided by the Club Racing office.
Merriam Websters had this entry, which helps illustrate my meaning....
Perception is a word that is often used to describe that a person believes that something exists in a certain manner, yet in reality, the facts don't always align with the belief, or the perception.Quote:
<some sensation of perception of the extremity after amputation is felt by 98% of patients
Well no, I don't reaaaallly think I could win a protest on my logic, but then again, innocent until proven guilty. It is a huge stretch, but what happens when someone gets protested for it and they stand w/ folded arms and tell the scrutineer to prove why it is wrong?
There are two sides to the IIDSYC bit which says, if you can, you can, free = free-for-all.
I just threw this out there for giggles, see what would happen. I have no reason to swap injectors at this time, but I am sure that someone would like to.
Matt
My guess is the car would be deemed noncompliant and you argument would be ruled a tortured interpretation.
Reminds me of the SSC driver who put mirrored film on his side windows of his X19. He then ran the runoffs with the windows up based on his interpretation that mirrors are unrestricted. He was told by the stewards that if he ran that way he would be disqualified. He won the runoffs by a good margin and was disqualified.
