Minutes are here
Tech bulletin is here
Of note in IT:
- CRX 1.5 (88-91) moved to ITB
- '86 Mustang GT in ITR
- ITB MR2 loses 100 lbs - Yea!!
- ITB Accord loses 100 lbs
- 4th gen Camaro 3.4L in ITS
Thanks Earl.
I see STAC cleared up the STCS rules regarding aero devices, which was part of my request, including definition for splitters. Awesome.
Question for the ITAC, I asked for an IT rules intrepration as well and all I got was "Thank you for your letter. The rule is correct as written." I am really confused since I was being as specific as i could with my question(s), or so I thought.
ITA Escort stays in ITA. Can't say I agree. Same motor in ITB already. If the process works, it should be an ITB or ITA car at different weights. Can't get to the ITA weight so it should be in B. Seemed like a simple request. Does mean it keeps 7" rims, which are easier to find. Maybe a more detailed request. One I wrote was simple, thought that'd be enough.
Yeah, which is kinda funny, as the response to my request was more verbose than I would have expected. Not that I'm complaining mind you (although I did think the reply made it sound like I was asking them to class MY car in STL...), but just seemed a little out of character.
You're welcome... ;)
We thought it was a reasonable request that deserved an explanation. So you got one.
Generally speaking about interpretations, there's disagreements as to whether we should use the committees, CRB, and Fastrack for rules clarifications/interpretations. Some say we should use the GCR-defined process, others counter that process is for trying to gain first-mover advantage on a competitive idea/interpretation. I infer that the current hierarchy leans toward "give 'em a reasonable answer, unless it appears someone's trying to twist a rule around and get us to effectively change a reg".
As much as I'd like to think it will help, it's not going to make up 3 or 4 seconds a lap at the Point! But we'll take it!
I'm not copying Mickey's letter from the board, but he effectively asked the same question regarding mounting / under car components that went unanswered by the COA in the moser splitter protest, coupled with a request for a general rewrite to clarify air dam / splitter mounting rules. the committee felt that this was partially a request for a ruling of legality, which ad hoc committees don't do, and partially a request to rewrite a long-standing rule. the committee members were split in our interpretations of current the rule's allowances and requirements, and it predating all of us (I think), chose to not attempt to clarify/modify and in so doing, make some portion of the cars out there illegal or codify a specifically more open rule, depending on your point of view on the matter. in the end, we decided to let the protest / appeals process iron it out.
I appologize for the terse response. the letter's point is valid, the request is for clarification of a gray area, and I would love to see a ruling made. unfortunately, the ITAC is not the place for such a thing.
if you want to submit a legality ruling, there is a procedure for doing so in the GCR, and I do think it's a valid question.
Mickey, the STAC never got a letter from you regarding splitters...were you asking for splitter clarifications in IT? We had requested that the definition of a splitter be placed in the GCR Technical Glossary but the CRB decided to keep it in the STCS for now. - GA
Edit:
A Pandora's Box in Improved Touring.
Splitters are not explicitly allowed in Improved Touring. However, the verbiage for airdams in the ITCS - which have been around for decades - are nebulous enough to where competitors have leveraged them to create splitters and undertrays. It's a long-standing argument, debated ad nausea on this forum over the years. First time I saw one I thought it was cheating, until I opened up the rulebook and read the words. Then I was convinced that while it may not be in the spirit/intent of the original rules, it was certainly within the letter.
And before someone throws back "how do you know what the intent was" argument, remember I was in IT back in the mid-80s when it was new, and I remember how cars used to look back when those regs were written...;)
If the ITAC were to decide to pursue a clarification on this allowing splitters, I recommend looking at the verbiage the STAC just proposed for 2013. I stole a lot of the ITCS verbiage for that change, detailing how an airdam, undertray, and splitter are to be done. The ITCS could use the same verbiage, changing only the allowance to extend 2" outside the bodyline and adjusting the ride height limit.
However, note that the reason we decided to allow STL to go 2" outside the body outline was because there are numerous cars that, because of the front end design, cannot have any splitter at all. We decided it was more equitable to allow all competitors at least a 2" splitter (splitters gain most of their value at 2"-3", from there the advantages drop off sharply.)
Please note that if anyone ever sends in requests that are intended for more than one committee (e.g., Super Touring and Improved Touring) it's best to breka them out into two different requests. The STAC never saw Mickey's letter; the regs we published for ST were purely and completely coincidental...
Chip explained the splitter rule clarification. It's probably one that needs to be cleared up via the protest process.
Tom, the default gain number for all classes is now 1.25.
3.4 Camaro is in ITS.
ITB 1.8L protege has an FP-DE motor, ITA 1.8L protege is BP-DE, just liek the Escort GT/LXE. we looked at weight in both classes, power potential, and got input form a member of the committee who owns and races an ITA Escort GT and the sum of that data said to leave it in ITA. I'd agree it's not a likely podium topper, but we feel it's still too much for ITB.
I don't want to jinx it before it's officially in the Fastrack, so I will save my thank youse until then. But you guys know who you are...
JUDGMENT OF THE COURT OF APPEALS
Robert Moser vs. First Review Rules Interpretation, COA ref. No. 09-RI-02
June 25, 2009
FACTS IN BRIEF
On January 1, 2009, Robert Moser submitted a request for Rules Interpretation asking for a ruling on the compliance of the spoiler/air dam on his 1988 Honda CRX Si ITA relative to GCR 9.1.3.D.8.b. Pursuant to GCR 8.1.4., Ken Patterson, Chairman of the Stewards’ Program, appointed a Review Committee of Rick Mitchell, Bob Eddy, and Tom Brown, Chairman, who met, reviewed Mr. Moser’s submissions and documentation, and spoke with Mr. Moser on several occasions. They concluded that the spoiler is non-compliant because the spoiler/air dam is not mounted onto the body of the car, as mandated by 9.1.3.D.8.b. Mr. Moser is appealing that decision to the Court.
DATES OF THE COURT
The Court of Appeals (COA) Dick Templeton, David Nokes, and Robert Horansky, Chairman, met on June 4, 11, 18, and 25, 2009 to
hear, review, and render a decision on the request.
DOCUMENTS AND OTHER EVIDENCE RECEIVED AND REVIEWED
1. Letter and supporting documentation from Mr. Moser requesting a Rules Interpretation, dated January 1, 2009.
2. Review Committee decision, dated May 18, 2009.
3. Appeal letter from Mr. Moser, dated May 28, 2009.
4. Appeal Notification, dated May 29, 2009.
5. Email statements from Bob Dowie, Club Racing Board Chairman, dated June 14 and June 24, 2009.
FINDINGS
In the original request, Mr. Moser sought “guidance regarding whether a ‘splitter’ design using two or more panels that attach to the integrated bumper, the radiator support panel and inner fender liners, and that has openings in the horizontal plane between the integrated bumper and vertical face of the splitter with free flow of air behind the face of the integrated bumper is legal on an IT car under 9.1.3.D.8.b.”Multiple components may be joined to create an air dam, whose shape is unrestricted - thus allowing a “splitter” lip which must not protrude beyond the body when viewed from above. The panel must be attached to the body or bumper cover (if the car is so equipped), but no support may extend aft of the forward-most part of the front fender wheel opening. However, there may be no openings in the horizontal plane between the integrated bumper and vertical face of the air dam (splitter) that allow the free flow of air. Any openings in the air dam must be ducted to either the brakes or the oil cooler. Mr. Moser’s design incorporates unducted openings, and is therefore non-compliant.
DECISION
The Court of Appeals upholds the determination of the Review Committee that the design is non-compliant; however, the basis for the non-compliance is not the attachment design, but rather the presence of the unducted openings. The Court of Appeals finds that Mr. Moser’s appeal is well founded and his appeal fee, less the amount retained by SCCA, will be returned.
http://www.tamemymind.com/blog/image...headonwall.gif
1) Thank you for time given to me and my request by the ITAC, much appreciated, honestly.
2) What has changed since 2009 which allows Mr. Moser to place a rules interpretation with SCCA, I assume, through the CRB/ITAC (www.crbscca.com) and I can't? What are we missing besides ad nausea on this topic?
3) After my NHMS incidents, I would like to re-install aeros devices on my car before spring. I submitted evidence to the ITAC/CRB that this is a grey area where I selfishly require clarification before I invest more money in my car and unselfishly give enough notice to both those with or without splitters time to act accordingly.
4) If you leave it the judicial arm of the SCCA, you are forcing me to protest one of friends in IT that runs a splitter to get a "clear" answer, which would probably vary by region... yeah, not very clear.
5) The final response of the Court Of Appeals on Moser request is VERY SINFUL in my opinion. "With all due respect" to the governing SCCA body, let's man up and let's make a decision. I hope the timing of my request is just "off" and if so, I will make 2 rules change request to the ITAC in the coming months.
Unapologetically and appreciatively, Mickey
Mickey
GCR 8.1.4 spells out "compliance review."
the downside is that it costs $300. I'm betting a fundraiser could be started to gather that as there is sufficent interest in a ruling.
IF the thing under review is found compliant, you get a letter saying so and the result is not published in order to maintain the benefit of an innovation. If the review is found non compliant, it will appear with a full finding in the COA briefs in Fastrack for all to see.
I agree that the court failed us in the moser case as there were too many aspects to consider and they failed the whole device on some of the less gray points, namely unducted openings between the air dam and body work. the undertray, aft-of body mounting (using the GCR definition of body), etc.. remain unanswered and "gray".
a ruling can give the rule direction, and if desired, members can petition for revisions based on that. that would be somethign the ITAC and CRB can actually work with.
NOT ITAC/OFFICIAL RESPONSE:
I personally feel the rule allows a full undertray splitter provided that the entirety of the thing remain forward of the front fender opening leading edge, within the overhead or plan-view of the body including integrated bumpers, and the body and air dam are sealed to one another so as not to create unducted openings or oepnings ducted in ways not allowed by the rules, such as in the moser example. I think the structural mounting or supports may be behind the body, such as OEM tie down attaching points on the bumper horns as are often used, and I think the COA agrees with me based on the moser findings (though it's not explicit).
others feel that an undertray is legal, but all mounting and support bust be to the body, NOT structural points of the car interior to the body, making the strength and thus the usefullness of an undertray low in most cases. still others think a splitter in any form is not allowed and therefore illegal.
Chip, thank you for your official and non-official responses. I will read 8.1.4 in detail tonight and decide how to proceed.
Looks like the CRX moved to B as well.
Improved Touring
ITA
1. #9410 (SCCA Staff) Re-Classify the Honda CRX 1.5L (standard) (88-91) to ITB
Reclassify the ITA Honda CRX 1.5L (standard) (88-91) to ITB as classified in ITA with the following
exceptions:
Weight: 2000 2110
Gear Ratios: 3.25, 1.65, 1.03, 0.82 or 3.25, 1.89, 1.26, 0.94, 0.77
So this was the August 2009 moser inquiry?
. COURT OF APPEALS
Robert Moser vs. First Review Rules Interpretation, COA ref. No. 09-RI-02 June 25, 2009
FACTS IN BRIEF
On January 1, 2009, Robert Moser submitted a request for Rules Interpretation asking for a ruling on the compliance of the spoiler/air dam on his 1988 Honda CRX Si ITA relative to GCR 9.1.3.D.8.b. Pursuant to GCR 8.1.4., Ken Patterson, Chairman of the Stewards’ Program, appointed a Review Committee of Rick Mitchell, Bob Eddy, and Tom Brown, Chairman, who met, reviewed Mr. Moser’s sub- missions and documentation, and spoke with Mr. Moser on several occasions. They concluded that the spoiler is non-compliant because the spoiler/air dam is not mounted onto the body of the car, as mandated by 9.1.3.D.8.b.
DATES OF THE COURT
The Court of Appeals (COA) Dick Templeton, David Nokes, and Robert Horansky, Chairman, met on June 4, 11, 18, and 25, 2009 to hear, review, and render a decision on the request.
1. Letter and supporting documentation from Mr. Moser requesting a Rules Interpretation, dated January 1, 2009. 2. Review Committee decision, dated May 18, 2009.
FINDINGS
In the original request, Mr. Moser sought “guidance regarding whether a ‘splitter’ design using two or more panels that attach to the integrated bumper, the radiator support panel and inner fender liners, and that has openings in the horizontal plane between the inte- grated bumper and vertical face of the splitter with free flow of air behind the face of the integrated bumper is legal on an IT car under 9.1.3.D.8.b.”
Multiple components may be joined to create an air dam, whose shape is unrestricted - thus allowing a “splitter” lip which must not protrude beyond the body when viewed from above. The panel must be attached to the body or bumper cover (if the car is so equipped), but no support may extend aft of the forward-most part of the front fender wheel opening. However, there may be no open- ings in the horizontal plane between the integrated bumper and vertical face of the air dam (splitter) that allow the free flow of air. Any openings in the air dam must be ducted to either the brakes or the oil cooler.
DECISION
This is a very unofficial "I'm not on the STAC and this is my opinion" post...
Chip, back in '07/08 or so, AJ Nealey and Gregg Ginsberg used the GCR process to get clarification on the intake on a competitor's ITA car. Along with their response to that process, they got a STERN rebuke about using this GCR process as a way to "clarify" a reg. My inference from the reply was that using this process to do ANYTHING but clarify something presented as a **NEW** competitive advantage was a waste of the process' time and an abomination of mankind (it was, IMO, a rude and inappropriate reply).
What you are suggesting is, based on that experience, a direct contravening of the GCR. And, I suggest, if a reg is not clear, and is in reality possibly being applied in direct conflict with the intent of the regs, it is decisively within the committee's responsibility to "clarify" that interpretation and/or correct the verbiage in the regs.
I do not think it proper to ask a competitor to develop a whole farcical protest to "test" validity of an application of a reg, nor do I think it proper to use that GCR clarification process to have the CRB - and by extension, the ITAC - make a formal decision as to the application of a rule. If there's any question - and by your direct reply above, there is decisive and well-known debate within the ITAC - as to how well or not a reg is being applied, it is within your authority - within your responsibility - to clarify it by interpretation and/or adjustment in the verbiage of the regs.
My 2 cents.
GA
P.S., please read my sig....
At best I think we had a split decision in the above. One group said it was illegal because of the mounting method and the next review said that the mounting method was okay and it was the openings that were illegal.
But my personal opinion is much like what Chip described.
GA, my reply is based as much on what I've seen here and at the track as what was discussed on the ITAC. the splitter / air dam debate is well known.
the ITAC does not provide legality rulings, only recommendations and clarifications. from the Advisory Committee Manual
The ITAC did not agree on the intent, so any decision would have been effectively a rule change, and we felt the letter was more of a request for a ruling of legality and that the pot was better unstirred.Quote:
Clarifications—While the Club Racing Board, when they write a rule, understand it totally and there is no doubt in the Board of Directors minds when they approved it, sometimes a few competitors will interpret it in a completely different manner. Thus a clarification is born. A clarification cannot result in a substantive alteration of a rule, merely an expression of its original intent. If it appears that a clarification will result in a totally new meaning, then it becomes in effect a rule change.
I did not know about the CRB/COA reply to Gregg and AJ. that's interesting, and a shame. one would figure that the PTB would relish the chance to do what they do on a volunteer level for a $300 fee to the club, particularly when it is a process spelled out in the GCR.
The thing here, Chip, is that we know there's a regs conflict, and we are choosing not to resolve it proactively. I don't think that's right. When the ITAC (and by extension, the STAC and all other "ACs") consciously choose to not address the conflict with verbiage updates, I think we're doing a disservice to the organization.
Said differently, I don't think it's right to recognize there's a conflict and choosing to respond with "rules are correct as written". By your own admission, they most assuredly are not!
But I see the issue here: you change the regs in one direction to make it explicitly compliant and suddenly a lot more people are doing it, or you change the regs in the other direction to make it explicitly non-compliant and suddenly a lot of people are illegal. Well, guess what? By ignoring the situation we are doing a great disservice to both camps.
And, as a great philosopher once said, "If you chose not to decide, you still have made a choice."
And there's certainly precedent: spherical bearings. Many moons ago (seems like forever), we had a spirited debate on this forum when I learned that some folks were using sphericals. As with the first time I saw a splitter, I saw those as contrary to the regulations (and, IMO, the spirit). However, unlike with a splitter, I looked at the regs and found nothing where they met the letter of the regs; after all, how in the hell is a bearing a bushing?? After more spirited debate - which ultimately led to my being "Earp'd" with a "Screw you, I'm running them, if you don't like it protest me" I decided to use the GCR process to get a "clarification". I put together what I thought was a well-written, well-researched, well-presented letter and I had the money in hand to get spherical bearings "clarified" in Improved Touring.
The day before I was to send the request - and I mean the very afternoon before that letter was to hit the post office - word came down that a "clarification" of the rules was going to be in the next Fastrack, making sphericals explicitly compliant. The ITAC/CRB was changing the words in the ITCS to specifically call out sphericals as allowed.
The inference was clear: sphericals were a tortured interpretation of the regs and not compliant to the letter (and by extension, the spirit). However the CRB decided that the "horse was out of the barn" and did not want to make a bunch of competitors change their cars back to bushings. So they changed the regs to match what people were actually doing.
Same goes for splitters: not explicitly called out in the regs, and the mounting methods are questionable. Within the spirit? IMO, not within the spirit of 1985, but certainly within the spirit of 2012. So why not go ahead and change the regs to match what "everybody" is doing? All it would do is even the playing field so that those of us that are not nearly as "creative" in interpreting the regs will understand that these parts are allowed.
And I do believe that is within the authority and responsibility of the CRB/ITAC.
Food for thought.
GA
changing the rule is absolutely within an AC's mission and "powers" but we chose not to. this rule has been this way for a LOOOOONG time, and it's not hurting anything staying as is. I've never seen or heard of a real "splitter" protest, just ones like moser (in part with added openings) and hines (grafted seamlessly into the bumper cover) and other than these online discussions, I've never seen or heard a spirited debate about them. so its not obvious to me that the rule NEEDS changing. yeah, it'd be nice for the sake of clarity, but there are bigger fish to fry and people are upset enough with rules creep/changes. the greater disservice would be to alienate one portion of the paddock or another with a clarification that they are currently living peacefully without.
lHold now, not to derail the discussion but I protest my name being used in the context of performing an illegal modification. While I mentioned running NACA ducts in my rear windows and would like to do it, after the discussion around them I'm coming around to them being illegal. And, regardless of the discussion, I never performed the modification. On the IT cars I build and tend to I have never carried out any modifications which I thought were illegal, were explicitly illegal, or that the general consensus was that the modification was illegal. So keep Earp out of it.
The splitter debate is important to me. We've not yet built splitters for the Mustangs and I sure don't want to run afoul of the rules, or spend a lot of time engineering a great splitter only to have it deemed illegal. Are there any pictures of this Mosler CRX splitter so one can visualize the shape of the device and the areas deemed illegal?
Ron
I don't believe the mosers had any illegal splitters. It was an alternate design they were considering that did not get approved.
I just love it. The Accord is set to a weight, it gets reviewed last year and its determined that the weight was in fact too low. The weight gets adjusted. Now some how it gets reduced? Wtf. What new evidence was provided to make this change again? Will other cars with similar engines get the reduction? This is pretty silly.
I'm with you Chris. I've really started losing interest in IT. These changes sure do see odd and can't help think about what politics were involved to push through.
Another data point.
My memory on this specific point is fuzzy, so it could be inaccurate (and AJ and Gregg can confirm/deny) but I seem to recall that they tried to use the protest process to get a clarification on a similar item on the same ITA competitor (same as the one they did the GCR process on). And, as I recall, they were also rebuked (by the local stewards?) for trying to use the protest process for clarification when they're supposed to use the GCR process.
Damned if you do this, damned if you do that.
So based on what we're reading, here's the options and possible results:
Use the protest process
- Friend A protests Friend B on the splitter/mounting ($25). Local stewards find it compliant/non-compliant. "Loser" appeals to Topeka ($25?) and Court of Appeals is formed. CRB and ITAC review the regs and decide what best meets the philosophy of the class. Interpretation is delivered back down. Regs are changed to meet the results.
Use the GCR process
- Friend A sends a GCR clarification request to Topeka ($300). Court of Appeals is formed. CRB and ITAC review the regs and decide what best meets the philosophy of the class. Interpretation is delivered back down. Regs are changed to meet the results.
ITAC/CRB take the proactive steps to clarify/change regs
CRB and ITAC review the regs ($0) and decide what best meets the philosophy of the class. Interpretation is delivered back down. Regs are changed to meet the results.
Seems to be a common theme here....
Or, continue the status quo
No one knows for sure what is compliant and/or not compliant; everybody takes a different interpretation and thus the regs are not applied equitably. Confusion, uncertainty, and general overall dissatisfaction with the process.
But, I suppose there's a third tactic...
Since the ITAC contends it cannot "interpret" a reg, then someone - and please decide one person, so the committee is not inundated - sends a specific request to the CRB to explicitly allow splitters and undertrays in Improved Touring that do not extend outside the body outline of the car, do not go farther back than the wheel opening, and are no lower than the bottom of the wheel, and to explicitly define the "body" in terms of where the pieces/parts can mount. This will result in one of a few possibilities:
- Response is "not within the philosophy of the class" thus clarifying the situation (win), or;
- Regs are changed to explicitly describe what can and cannot be done (win) thus clarifying the situation;
- "Rules are correct as written". Fale. We all agree they are not.
GA
initial change was to bring it inline with other multivalve cars under then prevailing rules. It would have stayed there after the ops manual update, too, in the "lack of better information" category. dyno info was submitted (and more was solicited) showing only ~20% gains but inconclusive to the peak, so we reran it at 25%. A LOT OF TIME AND ENERGY went in to making this right. the fact that there were 2 changes in ~1 year is unfortunate but we want cars to be run correctly Even though there are only 2 of these running currently that I'm aware of.
dave, we all know that prelude is effectively the same engine and should be treated the same way. write us a letter. or don't, if you are tired of seeing changes.
Splitter - someone write the letter tGA speaks of.
Here's a copy of letter. This has been and always will be a hot area since folks have bent the rules (creative interpretation) while others insist that it's airdam only for IT. Second, though I happy to see STAC getting splitter definition yet it TRULY belongs in the GCR glossary with measurement exceptions made under each class CS section.
Letter ID Number: #9062
Title: IT Rules Interpretation Request - Airdam/Spoiler topics
Class: IT
Request:
Dear SCCA CRB and ITAC,
This request may have come before yet debate continues in the IT forums and in my head when trying to make the next modification to IT car.
Two questions:
1) Many suppliers of airdams/spoilers including current IT racers are stating that radiator supports and front sub-frames are legitimate mounting points for otherwise legal spoiler/airdam kits. Suppliers of front aero devices to NASA drivers also want to provide their same products to SCCA IT drivers. Two, IT drivers designing their own front aero devices would like to make use of additional strong mounting points, allowing them to improve the functionality of their airdams/spoiler, i.e. easily adding splitters, stiffening points, etc. "Body" is defined in the GCR and integrated bumper covers are defined in 9.1.3.D.8.b and no where do I read that radiator supports or front sub-frames (as neither are considered part of the "body" or "bumper cover") are legitimate mounting points for an airdam/spoiler setup on an IT car. Could you please clarify? I submit 5 references.
a) 2 long threads in IT regarding the multiple view points on 9.1.3.D.8.b. I hope you find these threads interesting.
https://improvedtouring.com...light=splitter
b) 1 reference to the 2009 Aug Fasttrack regarding Moser's Appeal. As referenced in the above threads, the outcome of Moser's appeal simply caused more confusion and frustration regarding airdam/spoiler mounting points. Initially, the rules interpretation request found that Moser’s mounting points were illegal. Moser appealed the ruling and the appeal was denied not because of the mounting points but based openings in Moser’s setup were not used for brake ducts. So... are the mounting legal or NOT legal? The ruling did not clarify anything in that area. Very Sinful (on the part of the BoD)
http://scca.cdn.racersites.com/prod/...strack-aug.pdf
c) product issued by special projects motorsports. This is example where a supplier is interpreting IT rules, suggesting splitter kits with rad mounting points are IT legal.
http://www.specialprojectsms.com/per...vic-99-00.html
d) message from another supplier of airdams/spoilers to NASA and potentially IT community
"They (SCCA) pretty clearly define a 'box' we can play in. I already see a grey area that we could easily take advantage of. Most times in aerodynamic terms, words are inter-changeable. Do you know the email to the IT director or the director of you specific class? You could shoot them an email and get a definite answer but I'm going to say yes. The rules defining what we can do are almost identical to 944 Super Cup rules which I just made a splitter for a guy not too long ago. I can make something very similar to the picture you sent me in the link of XXXXX car. Send that to the director and make sure.
As for mounting, that’s not an issue. I worked in collision repair for 9 years. If you were to strip off all the bumpers, fenders, hood, doors, etc., you would be left with the unibody. The rad support and frame rails are part of that body. Again, I see this as just a word or phrase interchangeability issue."
2) The use of a splitter is more common in IT classes. Mounting points discuss aside, I believe the GCR may address the functional definition of a splitter under the "airdam" definition. What I find interesting is that under GTCS and STCS rules, one can find multiple references to "splitter" yet no definition in GCR. If there is one, I apologize and would welcome the reference. If there's not, I am requesting the CRB consider a separate "Splitter" definition in the Appendix F, revision to "airdam" definition in Appendix F to specifically mention/include "splitter" OR define splitter in the STCS and GTCS OR something better.
Thank you for your time and understanding. I welcome all discussion including over the phone and email conversations.
Best,
Demetrius Mossaidis #345562
"Airdam" and "undertray" are already in the GCR Technical Glossary; only "splitter" is missing. The STAC requested that our splitter definition be placed in the Technical Glossary but the CRB chose to move that into the STCS, likely to avoid any conflicts with existing regs in other classes. - GA
^ ah - thank you, my messaged will be edited.
