Originally Posted by
billf
Jeff,
As for clarification, your no. 1 point is your opinion ("I've been looking at one disassembled in Ron's garage for several months and while it may not make 2470, it can get close I think"). Therefore, your clarification is of your opinion.
Also: If the Process is taken at it's numerical values, the weight and Hp figures are to be the balancing point. What I mean is, from my observations it appears that these two, and some subjective evaluations, are used to "equalize" to some degree, the performance levels of various cars in the class. If so, then why allow an unobtainable weight to be used, since you wouldn't allow an inflated Hp rating to be used in the process either?
Without emperical evidence to the contrary, it seems obvious to many on this site, at least, that the weight of 2470lb with driver, is unreasonable since it requires a caged, wet, chassis weight of 2300lb from a street automobile that had a shipping weight of 3050lb (the listed shipping weight of my V6, base '02 Mustang).
If the weight was to be considered to be a valid starting point of the process, then, ideally, we should be allowed some alternative method of actually obtaining that weight, such as fibreglass fenders, etc, until the spec weight is achieved without ballast. I know this will never happen, having years of experience with the SCCA, and IT. But it was a thought.
It hardly seems even-handed (fair) to position a car that is grossly over process weight on the track agains't cars that need ballast (RX7 for one) to make their process weight. Especially since the only way to adjust the classing of the car in that class, is to allow an un-allowed method of weight reduction, or, an un-allowed method of increasing power (light weight panels/intake or camshafts changes).
Incidentally, I applaud one's attempt to take a car like the Mustang into that field of combat with those limitations (Having been there, done that...). My comments are directed at the process, and the way it's applied.
Good racing,
Bill:024:
