ITAC Math..... where would this fall??
Let the prognosticating begin. :blink:
Any guesses where this might end up? Not listing car make / model for unbiased guesses.....
Engine
SOHC 4 cycl w/ variable valve timing
Displacement 2378cc
Bore / Stroke 87 x 100
Compression Ratio 9.5 : 1
Valve Size (I / E) 34mm / 30.55mm
Chassis
Curb Weight 2880 lbs.
Wheel Base 102.4"
Wheel Diameter 16"
Track Width 57.9"
Front Suspension Type MacPherson
Rear Suspension Type Multi-Link
Brakes
Front vented disc 277mm
Rear solid disc 262mm
Gear Ratios
1 / 2 / 3 / 4 / 5
3.58 / 1.95 / 1.38 / 1.03 / .82
Wheels
16x6 46mm offset
5x114.3 bolt pattern
