***I can see you point but if that were true would it not be generally accepted that you could just remove the upper links instead of rendering them inoperative with foam and leaving them in place.***
Dick, as I read/understand the dictionary meaning of the word "added" one wuld implement something extra such as the third link is "added" while leaving the 2 OEM upper links in place witrh foam bushing material. As I read/understand the dictionary meaning of the word substitute one would replace something with another something such as I did with the lower control arms. I substituted the OEM rubber bushed lower links with tie rods with Heim joints.
