I'll just address one, as I se them all as the same. - then I will step away as I am clearly in the minority.
The SFI stamp is the required certification for your H&N. Snell is the required certification for your helmet. There are plenty of other certs that have to be met.
As to the cage, you COULD build a safer one...but you are only allowed 6 points plus an optional 2 forward bars for a total of 8. If you had unlimited latitude on attachment points, do you think you could build a better unit? If you designed such unit for say, another racing series, for 1st gen RX-7's - would you then stop selling your SCCA version because it then became your 'dumbed down' version that was known not to protect as well?
I think the difference here is perception and the starting point. The 'better' product was here first so people think it's a big deal to build a different version to fit rules. Just because the first one was over-engineered to the current spec doesn't make the second one a liability. If you can't build a good one to the spec, then don't. Just because it isn't as good as the first doesn't make it crap. It just makes it the best you can do within the guidlines - just like the cages.
Again, philisopically, I am with you all. The cert needs to be fought and addressed but I just see it a different way in the end.
Well don't step away because you are the minority by all means, it is often one person, one step, one word that starts the trip of a thousand miles (for better or worse).
