Well, since you asked (and by the way, a birdie tells me your SIR equipped BMW just set a lap record at Mid Ohio...congrats!!)....
The ECu was discussed at length.
Now, lets preface this by saying that at this point, this is what I think will happen, but.............there are no guarantees!
To summarize, I think it's safe to say that the majority of ITAC and CRB guys on the con call agree that it's a problematic rule, and in general, would support an open solution. The crux of the matter is the drawing of the line on additional sensors and such. In a larger architecture view, not allowing addition sensors limits the desired effect of the change, which is to allow everyone a fairer shot at taking advantage of the ECU rule than currently exists, as some of the cheaper EMS units aren't as flexible sensor-wise as the more expensive units.
On the other hand, allowing additional sensors/swapping sensors is seen as a step to Prod, and a loss of the IT philosophy.
At this point, we will submit the rule change as we wrote it ( at this point it's at a fairly progressive state, in order to look at the extremes) to the CRB and it should go out on next months Fastrack for member feedback, with a preface to summarize the situation and intent, and we'll see what happens.
It's a fairly major rule change, and while we need to be swift about it, we also need to cover all the bases, and be sure we've looked under all the stones before we finalize it. As such, it won't be in place at the begining of '07, but could be, if it works out, effective sometime early in the season.
To those that are anxious for it to happen, sit tight, the wheels are turning, and to those who are fearful, relax, everyone will have a chance to give input, and nothing is being rushed here. [/b]
