I misread your post. When you said "his" engine, I thought you were talking about the to RX-7 at the ARRC. My bad.
Tell us who the engine builder is, what the extent of the development is AND if it has programmable fuel management. Qualify your data if you want us to validate it.
You know the RX-7 weight. We have dyno sheets from a BMW guy showing 195whp. IT IS THE LOWEST WE HAVE ON FILE. Top cars showing 210 with full, 100% developement. Why are you using only the numbers that serve your arguement? We are using numbers supplied by BMW owners.
The best vs. best caclulations have been done. 195 is a very good build. 210 is tops we have seen. 175 is an average Mazda build. 181 is as much as we have seen but have heard 182. The following are UNrestricted numbers.
195/2850 = 14.62
175/2680 = 15.31
or
210/2850 = 13.57
181/2680 = 14.81 (182/2680 = 14.73)
There may be some advantage, but it is track/gear dependent, not outright speed beneficial. If you you want speed, revving past your power peak is not gonna get you down the track. Holding a gear longer into a corner without shifting can have it's upside - but it is about smoothness and maybe a slightly better lap time, but it isn't about overall speed.
Re-read the account on the review of the Huffmaster RX-7 video. PULLED down the straight by an obscene amount of car lengths. Please don't use the example as to the equality, then discount the evidence that it lays the pipe to the RX-7 in terms of power.
AB
