A pass between 1 & 2 when the double yellows don't show up until 6 would certainly not be suspect. You been snortin' too much rotary exhaust?
Just a splash mon, your adding like 3 splashes.......
Its all very scientific, we dont expect you to understand.
Hey, I was told "pour it down to the 12oz mark". Don't blame me if the car owner can't tell the difference between 12 and 21... :smilie_pokal:
Racing in the rain and being a wuss...
https://vimeo.com/67219468
Comments encouraged. Just be prepared for me to return the favor someday :)
PS. you can see BJ's crash just behind my rear view mirror. My suggestion would be lower your head relative to the screen to get a better angle.
Are the results from the weekend posted anywhere. Was looking to see the outcome of the ITB race.
Nice job. And nice job to Abhi!! He was driving like a mad man!! it used to be the braking zone on the inside down into 3 was always slicker than the outside, counter to the "rain line". I don't know if it's the bumps or if it's still like that.
And good job not hitting anyone......... or did you edit that out??
[QUOTE=mossaidis;347131]
QUOTE]
You should use the rain line on the exit of the bowl and in the left hander onto the straighaway.
When you get past those EP BMWs and catch up to me, you can see the difference in our lines. I was getting the power down sooner.
Also I started driving harder when you caught up to me. I got fast lap of the race on that last lap when you were chasing me. :)
Abhi
Yeah, Abhi had a really good rain line. You let a RWD beat a FWD in the rain?!? And if you could have caught Abhi, you could have hit him....gotta catch 'em before you can hit 'em.
Thanks Jeff! Abhi knew where the grippy lines were. Braking zones at 3 were tough to tell. Seemed that there was grip on the outside line which helped apex the barriers. There are LOTS of bumps at 3 still. Track should probably fix that. No, I did not hit anyone Jeff. The only damage was to your ego for not showing up. :)
For a tech guy, you can't format HTML to save your life. Or you don't care to. Probably the latter. I will look at the last lap again and re-evaluate. I know I screwed up the turn at bowl 5, late and no grip, and 9, with too much braking. I will say it was a great race with the EPs eventhough they slowed me down for sure. I was frustrated as I had to lift often coming out of 12, up 5-6 and into 11. I didn't get too aggressive with the south oval until a few laps on Sunday, too little too late.
Some ah-ha moments... should have, could have removed my rear sway bar. It was set at full stiff and my tire pressure gauge has read 4 psi too low for perhaps over a year now. It then dawned on me why I am going through so much rubber on the front tires in the dry and still seemingly slow and yet overcooking my tires... f@#k. Also, front chamber is at -0.6 and rear at -1.3 degrees. I can only lower the car so much before it bottoms out or it's below the 5" min. I refused to bend knuckles as other drivers do yet it's technically illegal. I guess I will need to threw money at off-set bushings.
mickey - who is hoping for another rainy race so to seek revenge.
If it is consistent, who cares?Quote:
Here's the next race, qual race actually, 5/26 AM. Nice spin at 8:38 and if I remember correctly, I almost got pinched going up the hill after 3.
https://vimeo.com/67229900
Whoa! Was than an IT-7 car going outside of you in Turn Three...?
:happy204:
Rain, Cold, and Wind made for an interesting weekend!
http://abudiphotography.com/scca-rac...s-may-25-2013/
http://abudiphotography.com/scca-rac...s-may-26-2013/
Enjoy,
Yusuf
Great shots as always, thank you for taking them and sharing them with us!
