In that case, I'll need $50. No, strike that. The GM top has me tee'd off because it doesn't appear to meet the spirit of the rules either. I'll pay 50% of the initial fee. On March 2, 2008, I'll check with local dealers and Pontiac HQ as to the availability of the part. If it isn't available to the public, paper will be filed at Summit.
Already covered, but shoot - I'd even enter the bloody event to gain standing for this one.
The hardtop should have been tossed to be consistent with the CoA ruling on the Mazda. Nothing I hate more than hypocrisy.
re:Protesting a "line" - flaggers can do that, but, and I've said it before, they would be foolish to do so.
re: 2-wheels in the grass... Hmmmm, I'm thinking that the GCR clearly defines the racing surface and it doesn't include the grass.
9.1.4. Off-Course Excursions
The driver is required to follow the pavement or marked course during a competition, and shall not gain an advantage from an off-course excursion. Unless otherwise provided by Supplementary Regulations , whenever a driver leaves an artificially marked course or an airport circuit with all four (4) wheels, he shall re-enter the course at the same spot where he went off, and cannot simply re-enter further down the course, subject to the directions of the Corner Worker controlling re-entry.
So, it putting two wheels in the grass was the fast line, you gained an advantage and are in violation of 9.1.4. (note to the GCR gnomes cleaning up language... define off-course excursion).
Reading this, it appears that the GCR has no requirement that you "reenter" where you exited on a natural terrain course. The reentry regulations have to do with airport and parking lot courses.
Then again, it would be pretty CS to protest someone over this.
As long as I have a wheel on the racing surface, I have not left the racing surface, and have not made an off course excursion. I am in fact very much ON the course. This can be modified in supplemental regs for a specific event if someone wants to prevent it, but the words written above do not prevent me from driving every corner with two wheels 4 feet in the grass, or dirt, or whatever is present inside (or outside) the curbing.
