Your welcome.
Your welcome.
On the subject of split starts. I am working on this subject primarily for the ITB/ITS group only correct?
Todd
I am sure that some ITA guys would like to rid themselves of the IT7 cars, but honestly, most ITA cars motor on the 7s down the straights, so my take is that it isn't an issue....
I believe that we need a split start with the American ITA cars out front. :p
Chris, I normally would agree with you on what you've said in regards to spilt starts. At any other track I've raced at thus far, I've never seen a real need to incorporate split starts although certainly do see a benefit (I mean experienced what the negative consequences) at the ARRC. When running Mid Ohio with the chicane, I found there to be only a few places that are good passing zones especially when trying to take on a higher HP car. The front and back straights are all in favor of the higher ITS car. Now maybe if we don't use the chicance, it would give me a chance to out brake an ITS car.Quote:
The best solution is to out qualify said car
The issue even if an ITB car out qualifies and ITS car is the at the start, the ITS car should have the advantage on that straight, then again on the long back straight. We (ITB cars) make a lot of our lap times on other areas of the track where its not possible to pass, or at least not possible without taking a big risk.
Multi-class racing means we have to deal with, uh... multiple classes.
I don't care and personally think split starts are kind of silly.
Keep in mind were talking a sprint race K. :) I really don't care much either way as we're all facing the same obstacles.
So Gregg, you headed South in the next month? The first cold one is on me.
Isn't it great to be talking about all of the fun we are going to be having at this early date? I hope you are still planning to be there.
In regards to the ITB, ITS split start. I have talked through the options with our Chief Steward and have come up with the following solution.
When you check in at Mid Ohio in August all ITB and ITS drivers will be handed a ballot to vote ( YES) or ( NO ) on a split start. A majority of the vote ( one way or the other) will decide how the race starts will be conducted. The chief steward will announce the results on Saturday morning before lunch.
I know that may not sit well with some but its the best compromise I can come up with. Besides I doubt many drivers are going to be against a split start anyhow. But the Chief Steward wants to make sure all the drivers involved get a voice in the decision.
Todd
Todd, if you feel that hardly any drivers will be against the split start they why add to the confusion of the weekend? IMO just do the spilt start that way everyone will know what is happening even before they get to the track. A split start should have no adverse effects what so ever with these 2 race groups.
"Just Do It"
Well, I'm not affected, but, I can't see anyone complaining that the opinion of the majority will be considered. Sounds fair to me.
Todd-
Thanks for the hard work, this seems like a fair option. I wont let this be a deciding factor anymore as I think you have done a great job at coming up with a solution. For us it will now simply depend on the checkbook status, we will probably register but I can't gurantee anything as unfortunatly we are growing up and starting to buy houses and and other stuff that seems to take away the extra $$$... :(
Raymond "Thanks again" Blethen
My thoughts, having done the ARRC with split starts and without:
- A championship style event should do whatever it can to get cars in the same class competing MOSTLY against cars in the same class. While there isn't nearly enough time to get each class its own run group, split starts do help.
- At the '05 ARRC we didn't get a split start in ITB/ITC, and there was a big shmozzle (sp?) between some front ITC cars and ITB cars on lap one. It was a matter of everyone getting bunched together and trying to use different class cars as picks against the cars in their own class. Split starts help eliminate that scenario.
- At the '04 ARRC we had an ITB/ITC split start with C starting about 30 seconds behind B. The start was completely clean for both classes, and by the time the fast C cars started mingling with the slow B cars and the fast B cars started mingling with the slow C cars everything had strung out a bit and passing was much easier with FAR less contact.
- A split start actually allows the top qualifiers of the slower class to do a real start. They get to take the green as a race group instead of being all spread out from the middle to back of a faster group of cars. When I was in ITC that was a BIG DEAL for us at the ARRC split starts because it was the only time we ever got to actually sit on a front row.
Again, a nice feature for an event that wants to niche itself as a big deal "championship" type of race.
You can go ahead and count my yes vote now.
Scott Giles
22 ITB
And one other thing that isn't obvious...
When a driver in a car in the faster class has a car from a slower class catch up...after starting 30 seconds back, it makes an impression in the faster class drivers mind...and he lets the slower car get by with less fighting. That's not the case when the cars start together...it's never pounded into the faster class guys head that he's actually slow. We drivers sometimes need it spelled out for us! Egos, and all that...
Scott....
Couldn't have explained it better......
Count my vote now also!
Jinx
+1 - Scott did an excellent job of summing it up! I'm in...
Extremely good point.
I was in the lead ITC "pack" at the 04 ARRC and when we caught B cars they were moving out of the way and not getting involved in our race.
At the 05 ARRC there wasn't an ITC lead pack until about 5 laps in because we had to work ourselves out of the B cars that were all scattered in the middle of us. If you are thinking that caused a good bit of extra contact, you are thinking correctly.
Again, if you want the event to be viewed as "special" and not just another weekend at Mid Ohio, this is one of the things you should consider doing. I'd easily skip another weekend to do one that I know will have split starts. NO hesitation on that one.
Changing subjects. This is what the run groups and order are looking like for this year. The only change that still may happen is swapping the SRF and Formula group.
Group 1.....ITS, ITB
Group 2....SRF
Group3....ITA, IT7, ITC
Group4....ITE, ITR, TCC, AS
Group5....SM, SSM
Group6....CFF, FF, CFC, FC
All the 40 min/ 22 lap races will be after lunch this year.
Todd
I'm putting together an "intending to run the I.T.SPEC*tacular" bio page together for the cincy website. If you are interested in being on the list let me know. I do have last years page if you just want me to copy the information for this year.
Todd
There is new material posted on the web site. We have the 2007 overall champs listed with pictures. The web master is promising me he will have the first of the driver Bio's up today. I'll let you know when they are up. www.cincyscca.com
We also should have Phil's Tire Service info listed soon.
Todd
