I think a root cause of the objection of V8's in ITR is the way the committee assignes clasifications and weights using OEM peak hp. I think this really puts highly tuned honda VTEC cars that have 100 hp/liter at disadvantage when classed against less than 33 to 45 hp/liter american cars.
I have put a lot of work into my VTEC delsol, (Hondata 300, Hytech header, tuned intake, extensive tyno tuning) to get your expected 25% hp increase . I got a bit of midrange but no substantial increase of hp. The result was 150 whp at 7400. Of course from a 1.6 liter engine thats darn good. Why would I expect more? Torque (ignition timing, displacement, and compression ratio) are already good, and the engine is limited by valve float at over 8000. So, no surprise it realy can't be improved upon when its already 100 hp per liter. What do you expect; 125 hp per liter?? That would be a world challenge motor. Forget it.
(ps our 1.8 liter Integra Type R is 184 whp or essentially 100 whp/per literin IT trim and 109 street hp/liter per stock oem rating).
Meanwhile, take you '80's smog motor that that at 33 to 45 hp/liter, put a big exhaust, intake system, and wake up the engine management, extend the RPM/hp peak from 5000 to 6000 rpm and a 25% increase to 40 to 60 hp/liter sounds doable.
The last point is, cheating. At 100 hp/per liter, something like a type r has nothing to work with (it always has a race cam, and it is already reving to 8400 rpm); do I need to use nitrous?. Besides, if cheating is my goal, it would be a lot easier to start cheating with a car who puts out 40 hp per liter than one with 100 hp, come on....
I looked at the ARCC results, no honda's are entered in ITS. The beauty of the modern japanese cars is that on the engine side, they are pretty fully developed and are near IT maximum as stock. Accordingly we are fighting with a way short stick in IT against low power to displacement V8's.
I really think the ITAC should use something other than OEM power when balancing cars. It puts modern cars at a disadvantage, and it puts VTEC hondas at a huge disadvantage.
If the ITAC fixes the way that hp, is rated, I would be fine with V8's in ITR. Don't, and I think more ITR owners will feel the way that current Honda VTEC owners do about their chances to be competitive.
For comparison from Andy's notes and using his formula (IT Weight = 9.95 * (Stock HP) + 890.8), here are ITR stock power per liter
BMW 325 --75 hp/liter
BMW 328 -- 70 hp/liter
944 S2 --66 hp/liter
Maxima -- 72 hp/liter
300zx -- 79 hp/liter
Supra -- 78 hp/liter
Acura type R -- 109 hp/liter
Camaro (5.8 liter) -- 33.3 hp/liter
Ford Mustang (5 liter) -- 45 hp/liter
For some time, the IT formula has killed competitiveness of VTEC honda's. Who knows, if we let V8 cars at 33 to 50 hp/liter use the same formula as 70 to 100 hp per liter nissans, porsche's and toyotas, maybe somebody other than the Honda VTEC racers will realize how unfair the present rating system is.
Please tell me how to get to 125 hp/liter in a honda legally and I will be glad to oblige in retracting these comments.
