The 600-lb gorilla on this subject is enforcement. Kirk's emerging Laws of IT Rules Enforcement, for consideration...
1. It is not possible to write a rule that enforces itself
2. We have to be willing to enforce what we put in the rulebook (Corollary - Any rule that isn't enforced, might as well not be a rule)
3. If we dink around with rule wording in an attempt to get around the First Law, living with the Second Law gets awfully difficult
Pragmatically, this issue approaches the point where there are really only two options that are amenable to enforcement - "you can't do anything" or "you can do anything." Of course, I don't have the generalized fear of technology that some do (e.g., ABS brakes turning everyone into Randy Pobst).
So if my stock throttle position sensor dies, I can't replace it with a new one? :)Quote:
ECU is unrestricted. Stock wiring harness must remain unmodified. Addition/Replacement of stock sensors is prohibited.[/b]
On EDIT...
Please, please, please resist the temptation to toss "not allowed" language into the mix, all willy-nilly! "You didn't say I couldn't modify the connector that snaps into the ECU - so there."Quote:
Stock ECU's must be retained. Removable chips may be substituted. OBD cars may be re-flashed. No other modification to the OEM housing or circut board is permitted.[/b]
