No offense but I don't see where you have any way to substantiate that the weight addition has ANYTHING to do with this. Anyone not doing continuous maintenance on these cars and running the ECR series WILL have failures. Continuous maintenance is an amorphous concept and has a lot to do with where you are racing and the conditions.
And continuous maintenance for this car at 2140# was a front left wheel bearing every six races at a MINIMUM and if it goes a weekend too long, a brandy new hardened hub too. And a weekend at Kershaw alone could fry a bearing due to brake heat. You are easily in for a halfshaft a year at BEST. You will replace the right front wheel bearing at least once a year. I was rebuilding both front calipers every three race weekends and every other one, would replace w/ new if I could. For two years, we never started an ECR weekend without both brand new brake pads and sticker front tires. And at Kershaw, the pads would not see a caliper until the pace lap. At RRR, we wouldn't even count on Toyos to last an ECR + practice + qualifying. Those are the minimum costs to try run at the front in the ECR series (and a great part of running at the front in that series is making it to the end cause invariably, your competition will not for one reason or another).
To refute your claims that this weight is "the" problem for the car - I bought two 225 R3S05s at VIR in March and heat cycled them on Friday test day. Now it goes without saying that I had some rear wheel bearing issues up there but that had nothing to do w/ weight - that was a tolerance problem (and that could have affected my car at 1800# just the same). Those two front tires ran the ECR quali, Alex's stint in the ECR, my SARRC, a full test day at Kershaw, 2 practices at LMS, ECR quali at LMS, the ECR at LMS and then my SARRC on Sunday - and I turned my fastest lap of the weekend on the last lap of the SARRC race. If the weight was so problematic, there is NO way any of that would be possible. And ask Puckett what he thinks of my brake wear.
You guys have this wrong if you think the weight is affecting these cars' reliability. At least at this point you don't have me convinced and if I thought it was, believe me, I'd be the first guy to write a letter. Now that's not to say that over time, considerable time, I might be convinced the weight is an unfair hinderance but as for now, I do not believe the sky is falling.
Well, thats all great Adam, and you aould certainly know.
