For flag stations to be effective, they need to be in the target line of sight of the driver. It's sweet and all to tell drivers to always make a concerted effort to look away from the road to recognize flag condition, but in reality that just doesn't happen.
As the driver leaves T9 the car is pushed far driver's left and the flag station for T10 is not visible behind the wall. As track-out finishes the the driver's gaze and attention shifts to straight ahead and slightly driver's right, to the turn-in point of that next corner, and away from the flag station on driver's left. That corner station does not become visible from behind the tire wall until the driver is pretty much entering that next corner (T11?); by that time the corner station is now directly abeam the driver. As the driver negotiates that corner his gaze turns only about 30 degrees left for the entry to T12 and the corner station is well past abeam left and fading away. Thus, unless the driver intentionally looks left to the station while going through the process of entering the corner (something that is not instinctual) or has his attention taken there by contrasting movement (as Kirk describes) then it's easy to miss flag status. A far better location for that flag station would be at the end of the Aarmco on the short straight, where the driver can easily determine flag status.
The same exact visual/psychological problem exists at the T2 flag station: driver's attention is slightly right to not hit the concrete wall, flag station is abeam to driver's left (or did we change that? I remember there was talk of it).
I've trained myself to look left at these stations each time I'm there; they've saved me more than a few times. But in the heat of the battle it's quite easy to miss those. So I don't automatically blame anyone when they miss those flags; they're in terrible, ineffectual locations.
My rule-of-thumb is that if you can't see the flag station for a reasonable amount of time within the narrow field-of-vision of the front windshield of an in-car video, then the driver can easily miss it.
GA
