David, with respect, this is a much more multi layered issue than might first be apparent.
1- The club is not super healthy when it comes to new racers and new blood.
2- The club doesn't have a surplus of people wanting to spend dozens of weekends getting their scrutineer chops and stamps of approval
3- The GCR is chock a block full of categories and models.
Reality: A billion Spec Miatas have rolled up for inspection, and I'd bet many did it at an event, with their run group going out in the next hour. Should it happen like that? nope...but it does. IIRC one of my cars got it's annual under similar conditions. And those tech lines are long. Scrutineers are stuck between a rock and a hard place: Know everything about everything, do an hours work in 10 minutes, make sure everybody in the tech line...the "Customers" , get on the track on time, make sure everybody is safe and make sure everybody is legal and meets the specs of their class. That's a daunting list, and one that is nearly impossible. Some people will not get their way, and I can tell you there have been people who missed their run groups because an inspecor was tied up discussing the legalities of a cage with someone further up the line.
Should such cages be turned away? Not sure on that. If the car has obvious illegalities, and its a school car, I'd suggest a "fix by next event" notation be added to the logbook. If it's an experienced racer then the "Fix by" is a bare minimum.
But, in any case, some will slip through the cracks. Thats where competitors come in. An illegal cage is an illegal cage, whether it has a logbook or not.
I imagine you feel that there are some cages that have been given logbooks (without notation) by tech people who knew the cages were illegal. I don't have any first, or second hand info on that, but if it happened, I'd be disappointed.
