Originally Posted by
Knestis
So, to the CFR situation specifically...
Get a group of like-minded folks together informally, with the mission of getting the cheating under control.
Make sure you recognize that you're talking about shifting a culture, one that's pretty entrenched and supported (explicitly or tacitly) but a lot of folks with $$ invested in their current (cheaty) positions. Commit to the challenge.
Communicate as broadly as you can - starting right now - that y'all are on a mission. It's a friendly mission but some folks' feelings might get hurt. Give 'em as much warning (this off season) as possible to get compliant or risk getting dinged.
Define a set of specific strategies to actually DING SOMEONE and put them into action. The list from this conversation is a great start:
** Get friendly tech peeps to hold "impound all" with hoods open
** Vow to collectively - and informally - point out any obvious visible illegalities that can be seen to every entrant; reinforce that, as a group, the category DOES care about whether every car is compliant
** Pick some low-hanging cheater fruit - protest visible-and-consequential items on a few cars, and protest a couple of the more grievous suspected problems that require technical help, if not invasive tear downs (e.g., pull valve covers to compare easy cam measurements [lobe height minus base circle], gearbox ratios).
We've joked about "Florida IT" for the last decade. It's part of the reason I NEVER made any effort to come there. I got a clear picture of what we'd be walking into from David Ellis-Brown's "recommendations" of what we should do to make a MkIII VW fast, back when we built Pablo I...
It would be nice to see the accepted standards change.
