Originally Posted by
CRallo
My post was a response to others. Did you read them? I ask because you might misunderstand my post if you took it out of context.
I took "It says that it(whatever you happen to call it) must be attached to the body, but not ONLY the body" to mean that you may also mount the spoiler/airdam/splitter to both the body and somewhere else where the else is not an integrated bumper assembly. Where mount is defined as attached.
If that is not what you meant, my apologies. If it is what you meant (at least for IT), then you are mistaken. Attaching the splitter anywhere else is not a permitted modification.
9.3.D ....Modifications shall not be made unless authorized herein.
9.3.D.8.b ....The spoiler/air dam shall be mounted to the body
9.3.D.8.b ....On cars with integrated bumpers, the front spoiler or airdam may be attached to the bumper cover.
Whether the allowance to mount to the bumper cover gives an alternate mounting point replacing the body or an additional mounting point if the splitter is mounted to the body is unclear.
Oh and on that theme, your conclusion at the bottom is not a true statement/summary.
None-the-less, the GCR tells you where you are allowed to legally mount the item.
