Originally Posted by Letter to the CRB #5434
9.1.3.C, Paragraph 2:
"To maintain the stock basis of Improved Touring, updating and/or backdatingof components is only permitted within cars of the same make,model, body type (e.g., sedan, station wagon, convertible, etc.), andengine size as listed on a single Improved Touring Specification Line.Any updated/backdated components shall be substituted as a completeassembly (engine long block, transmission/transaxle, induction system,differential/axle housing). No interchange of parts between assembliesis permitted, and all parts of an assembly shall be as originally producedfor that assembly (such parts may, however, be coated, painted orplated). Additionally, it is not permitted to “create” a model or type ofcar by updating or backdating assemblies. Parts or assemblies which themanufacturer lists in factory service manuals or parts guides for a particularmodel which supersede or replace original parts or assemblies arepermitted. Documentation of the superseding parts or assemblies must besupplied to the Club Racing Department and the appropriate part numberslisted on that particular model’s specification line."
has been variously interpreted and needs clarification. Assemblies, as defined, are at times updated through a model run on the same make/model/body type/engine size from a given specline, and the use of such an assembly with other assemblies could result in a configuration never offered for sale.
the question is if this comingled "best of the breed" is permitted assuming it satisfies all of the requirements for make/model/body type/engine size from a given specline, or if such a combination results in the "creation of a model or type of car", or where the line is between these readings.
