Originally Posted by
Greg Amy
1994 and 1995 Miata are on the same spec line. 1995 Miatas are rated at 133 horsepower. Ergo, both cars, if on the same line, should go through "the process" at 133 horsepower.
And before you "go there" again: if we're going to give horsepower "credit" for cars where the factory has done things "towards" IT-spec changes, then we need to do it fairly and across the board. Let's "credit" the Integra for Acura's good work on that engine, and let's "debit" the NX2000 for Nissan's crappy work there. Because "what's good for the goose..."
And (to address your next defense) if the 1994 and 1995 Miata were classed on separate lines, and the 1995 was classified at 2485# - which in all fairness it should be - then the 1994 Miata, once proven to be the overdog that it is, would eventually get that same 2485# and we'd be back to the same end. But, as it stands now, you (plural Miata drivers "you") get to burn your candles at both ends without injury.
That is inequitable.
The Miata is an overdog. Plain and simple. I really do like 'em, it's a wonderful car; just like the E36, it's a car that's truly worth more than the sum of its parts. The very fact that a full-up Spec Miata - probably a 8/10s prep IT car, if even that once you consider the suspension, engine, and tire differences - can be reasonably competitive in ITA is proof of that.
Want to stop the bitching? Follow your own process, the one you both simultaneously praise and hide behind, and put the Miata at 2485#, which is the weight it would have using a horsepower rating of 133. The car will STILL be extremely competitive and then you can truly hide behind "the process" without appearance of hypocrisy.
Really, "just sayin'". - GA
