Not so fast there, Speed. More drivers are likely to be impacted by this because they are using older but still completely serviceable Nomex, PBI, or other suits that don't have any SFI or FIA certification, than are likely to get trapped with only 1986 FIA-spec suits.[/b]
Right, but if you don't put a spec on the suits what requires a suit to be fireproof? And by that I mean new suits as well. Under the current rule you could go out and make your own suit and as long as you use the right material you can use it. even though it may fall apart in a fire.
