Originally posted by Banzai240@Sep 14 2005, 03:31 PM
You guys want to know why SM is SOOO much faster than it appears it should be??? Because there are HUNDREDS of them out there tweaking, tuning, adjusting, and then SHARING that information with each other... finding the EXACT correct tire pressures, the EXACT right caster/camber combo, etc., etc.... The same might be said about the CRX... Lot's of them out there, usually driven by friendly guys who talk to each other...
The only thing that can be justified in your post is that there is the large number of Spec Miata’s and the progress they have made. There is now a large number of E36’s, several really good development programs, and an abundance of really good go-fast parts. And this might be a shocker, we BMW drivers do share setup information.
If you run the numbers on the RX-7, both theoretical and actual dyno numbers, you'd find that it's classified as the process defines. The same is true of the 240Z. The 944 is too heavy... The 944S is a bit too light... The 240SX is close, but will require an 10/10ths effort to make that weight... Several cars are overweight at this point, some are slightly underweight at this point... Some are in the wrong class all-together... The same pattern exists in all the classes...
Interesting that the members of the ITAC all consider there cars to be classified about right. Andy - RX7; Darren - 240 SX. Might be time for a little more diversity on the ITAC?
