Right there:shrug:
I do not know what the rear suspension design is on a 240SX. But, if they use the same design as your #3, then my same position applies (read my edit in the above post).
But that still doesn't allow #4 to be replaced with anything but a stock-equivalent ball joint. - GA
Struts aren't a subtractor.
Here's one upside down:
http://gallery.voodoo-people.com/alb...um499/02_G.jpg
Notice the ball joint on the lower a-arm, that's what binds when the 240sx gets lowered, that's why they need spherical bearings. Since this ball joint can be swaped out for a spherical bearing, why not the front one?
100% with Greg here guys. Suspension bushings are suspension bushings. Ball joints are ball joints. Ball joints may 'act like a bushing', but they are not 'suspension bushings'. There is no provision in the ITCS to modify or upgrade the ball joints.
HuH???
Fist, where does that first quote from Tristan come from?? Not this thread that I can find. And Kirk (Knestis) the fellow referenced in the quote in the "Bite me" section.. (?!?!?!?!?) hasn't even posted on this thread.
So, I fail to see how this particular item has been protested and or upheld. Can we see proof?
Jake,
I'm from Missouri, so I understand your need for proof. But, really you should remember it's from Greg's spherical "bushings" thread top of page 14.
https://improvedtouring.com...ension&page=14
Again, if it's legal on the rear why not the front? Back to the definition the first two words are, "A Bearing" seems to me that we're just swapping one "Bearing" for another.
ps. I was going to take the reference to Kirk out, but then it didn't make sense. So I appologise for draging that part back up after it's been water under the bridge for years.
Who said it's legal in the rear? Again, just because people are doing it, doesn't make it legal.
Just got off the phone with the local guys who run 240SX's. They do not know anyone who has replaced the rear ball joints with anything aftermarket. In fact, he went on to say that with all the 'real' rubber suspension bushings replaced, there is no bind AT ALL with that ball joint. He ran the suspension through way more than its normal range (with no shock) and proved that to himself.
We also pointed out that the original supplier of the 'kit' for SB's, Westek (sp?), did NOT provide anything aftermarket for the rear ball joints.
LOL - I'm glad the forum has the "view post" feature in quotes, 'cuz I had no luck searching on the string "bite me." :)
I'm late to this party (who knew it would get interesting?) but golly, please do let it be true. Please, please, please.
I'd personally front development and the first production run of CMS "super proven-legal spherical lower strut bushing kits" for the full range of Golves. And if you order two sets (should have spares, you know), we'll throw in a pair of CMS "super proven-legal tie rod end bushing replacement kits," featuring Steer-O-Matic(r) correction.
EDIT - I'm positively giddy here! Imagine Pablo being able to drive around a corner at Mid-Ohio. Whew. I'm going go sit down for a minute.
I'll admit I'm not an expert on anything Nissan, I just remembered that TurboICE posted a picture of the rear suspension, and remembering how it worked, I looked for his post.
That being said, the reason for alternate bushing material is what? To remove rubber elements anywhere In the suspension, right? So what about rubber isolation in the balljoint?
Wow, I just went back and read the last couple pages of that thread...
(low whistle)
man, those were good times huh!? ;)
Place seems quieter now that DD is SM-ing.
I'll say this, my NEXT car looks like it's gonna have some trick chit under the fenders.
+819trillion. Thought that NX was hot shit before? Hoh-lee kee-rap: imagine that engine and it handles...oh, Timmy...? Looking for some easy "partnership investment" to get that car back online...? I only want to use it, oh, one event a year...
Keep me posted on this "ball joints is bushings" stuff, please?
GA, watching intently...
So what about the RSX it's stock shocks look like this with a built in steering arm.
http://www.k-series.com/media/albums/album82/aal.jpg
Now Ignoring the remote resevoir would it be legal to replace the RSX strut with one shown like below with a adjustable height steering arm?
I enjoy Greg and Jake's "please let ME do this" posts, but I can guarantee you guys RIGHT NOW that nobody on the ITAC or the CRB thinks this is even CLOSE.
