Scott,
I like this idea because of the opportunity to run in a national class relatively cheaply. My own circumstances would probably preclude doing so right away--just got married at 60, a five year old came with the package and there is one on the way--but I am far from being over the hill as far as racing is concerned.
I especially like the IT engine part. I built my engine probably eight or nine years ago, grinding my side plates on a rotary table and lapping them by hand with soap and water using 220 grit wet-dry paper on a piece of glass plate for a sanding block. After all these years the engine was strong enough to set fastest lap at the ARRC a few years ago, though a transmission problem kept me from the podium. There is a certain appeal to never having to touch your motor. I don't like the idea of cracking the lower end, however, to go to the trouble and expense of lightened rotors or any of that stuff. I still run the cast iron apex seals, too. All of my power is from attention to detail on the outside and fine tuning on the dyno to assure A/F is right.
I just bought two brand new sets of Panasport wheels a couple years ago and don't like the idea of throwing those away, either. The 13 inch tires on a very light car would probably do well in the class, and are far easier to fit, lower the center of gravity and frontal area for a given optimal geometry, are lighter, and have considerably less rotational inertia under braking and acceleration. The low power of the IT engine would compliment this combination. All I might need is a set of spacers to run the wider slicks.
Taking stuff off to lighten the car is cheap, too. Running without the now problematic stock wiring harness buried under the dash would be heaven.
Have you considered asking the Competition Board if there is any set of circumstances they would consider to allow a very, very limited prep first gen in GP, ASSUMING the car would be specified not to be an overdog? Their response would indicate a direction you could go to get the car in. Otherwise you could submit a million responses with no feedback until you just get lucky. Or by that time they would be tired of you and wouldn't give you the time of day. I am a believer of understanding a problem is the first step to solving it, and much easier.
Incidently, I have not followed GP so I don't know what a good lap time for a GP car is at Mid-Ohio or Road Atlanta to compare to my own times, which I beleve are probably right up there with any legal ITA or IT7 car. Can anybody give me a number?
Jim Susko
G-Force Engineering
Thanks Jim,
