Bill, I believe (and I think Stan will agree) that this is the new SCCA. We are trying as hard as we can to get rid of the old way of classing cars. I call it the plate method, you through a plate up in the air and see how many shots it takes to break the plate. Three shots SSB! The ITAC has done a great job using a process to equal the playing field with out favorites. Stan and I are numbers guys and we believe a similar process should be used in all classes. I agree with you about the limited prep prod rules and I was going to make it my mission to get in the middle of it and try to make it right. Once I started to do some investigating and found out that even long time prod guys do not know why the rules are the way they are, it left me scratching my head. Then the Prepared class came along and I believe that it is a viable solution to the SCCA's future, so that is were I have put my attention.
As for the RX7, people have been trying to get it into ITB for as long as I have been on the CRB/ITAC. The simple turth is the car has way to much potential for ITB or it will have to weigh so much that it would not be any fun to drive. I believe that a well prepared RX7 is still capible of runing at the top of ITA, specially after the 100 pound weight reduction. By no means do I think it is the car to have in ITA, but it can and does compete well in ITA. The only reason we dual classed the ITS/ITR cars was we were not sure ITR would generate the numbers, so why make guys run there. PK
Peter,
