You can use the same pieces that Ron used, but put the adjuster in the lower arm pocket and don't weld it. If you grind down the edges, it will fit nicely in the arm and pivot a bit as the arm travels. I have done this on a few Mustangs. If I can get a photo of my car I'll post it. On the rears you can use a similar adjuster and just have it lay over the rear arm not welded to it. Not that I think that what Ron did was wrong, but the way my is done prevents others from saying that I am cheating.
I would like to see a picture of this. What are you grinding on? It has been said earlier that grinding on anything is cheating. Are you talking about grinding on the adjuster?
