Originally Posted by
lateapex911
Matt, thankyou for writing paper. That is something that obviously needs to be done, and clearly needs to be done more often. That said, please appeal. Every one of us needs to contribute to the knowledge base on other drivers. This is your time.
I'm sure the Acura driver is a nice enough guy, but you were MUGGED, Matt. What he was doing way over on the inside, WAY too shallow, with WAY too much speed, I'll never know. Amazingly stupid for someone with a racing license . Of COURSE he's going to go tangental. Ever heard of an early apex? I don't for a second buy the "my tires were going off" bs. Well, if they were, then why weren't you adjusting your lines, braking points and throttle openings? That's called driving.
Simple fact is you let him all the room in the world, and you can't just vaporize. He SHOULD have been right up close to your passenger door in the braking zone, and at turn in, in order to:
1- Make sure you know where he is,
2- Make the corner as large a radius as possible, since he may, or may not be able to clear the overlap by track out, and might not be able to use the last 5 feet of track at track out.
3- and to control YOUR turn in. YOU can't turn in until HE turns in. (not that you did anything wrong, but, he was so far out of your field of vision, it would have been easy for you to have assumed he backed out and you might have taken a crack at getting closer to the apex. (boom))
This one is black and white, yet it appears he doesn't feel he was in the wrong. He was. 100%. He needs to "Get that".
