I'm sorry Andy, if that's the case, you guys threw the PCA rule right out the window.
Taken from 17.1.4.C of the '06 GCR
I don't know how you read that, but the way I read it, is that the ONLY way you can implement a restrictor, is after a review of results. There's nothing at all in the preceeding paragraph (which deals w/ the initial classification process) that speaks to using an inlet restrictor. Here's the first part of that paragraph.
All it says is that a minimum weight shall be established. Says nothing about a restrictor. So, either all the cars were treated like they were new classifications, and run through the process w/o any consideration given to results, or it was a post-classification adjustment, at which point you must consider results, if you're going to implement a restrictor.
I'm not trying to pick a fight (or pick the corn out of the shit), but that's what the rule says.
Bill,
