If you're thinking about building an E46, get an ECU solution figured out before you get too far into the build. Double VANOS, both continuously-variable = potential for good power, but also means you're going to need a GOOD computer solution...and that ain't gonna be cheap.
The SIR on a weak E36 2.5 motor knocks 10hp/10ft-lbs off of it, and changes the AFR about 4 points (and I don't mean 13.8:1 to 13.4:1) across the board. Looks like a good Megasquirt build can control everything necessary with this engine, though, including the simpler "on-off" VANOS.
I honestly giggled in my helmet a couple of times when I jumped on the brakes in our E36 coming into the braking zone at T10 in Atlanta. If we can keep that RF from locking as easily in other spots (coming into T3 and T5 in Atlanta, for example), we'll be in good shape on the braking front.
