Sorry but a mistake in the spec line does not trump a written rule in the ITCS. If it says you can, you can, regardless of any missing information elsewhere in the good book. It doesn't just say you can, it says you have to run a stock gear set, and that is what it would be. So, I submit that the rule is not omitted from the ITCS and is quite clear, but the 'cheat sheet' at the end of the book has an omission.
Agreed that it may have to go to appeal to be resolved if a protest occured, but the better solution is correction via errors and omissions. From what I can tell my 86 GTI came with the listed 2nd, but I would bet that plenty of cars are out there with the 1.94 and don't know it.
I will pull together some documentation and send it off.
Looking at the spec line more closely they also have errors in the brakes. Rear disk is 227mm not 244mm, rear drum may also be 180mm drum as this was delivered until the late 80s. I expect that this is not uncommon and similar items are in error throughout the list. That does not change the rules.
I agree Chris, they should fix it. But I disagree w/ you about a spec line not trumping a 'general rule' in the ITCS. It does in fact trump the 'general rule'. You look to the general rules first, and then you look to the spec line. There are cases where the spec line countermands the general rule.
