They use parallel bars because the spacing between the bars must be small.Quote:
Originally posted by charrbq@Oct 6 2005, 03:43 PM
Two cents. I'm not a welder, nor do I play one on TV, but I've seen the need to use one in the past.
My guy tells me that it's much harder to make an "X" and gusset it properly than to weld two bars parallel to the front and main hoops. Plus, the bars are continuous, not cut and rewelded. As an aside, he offered to modify my cage in such a manor and add small bars between the main door bars to add support. His and my theory is that in a side impact event, with the "X" bar configuration, it would be a lot easier for the intrusion of cars and car parts into the cockpit than with the parallel bars.
I guess you could look at shark cages as an example. They put parallel bars in those to keep the bad things out.
[snapback]61944[/snapback]
A properly designed and executed cage with an X will tie to the dash crossbar and main hoop horizontal crossbar. This will be significantly stronger than two parallel bars welded to verticle tubes without other support.
