***dq'd last time out for 7 lbs under***
1 1/2 gallon of beer the night before would have taken care of that. Or 1 gallon of fuel.
Have Fun http://ITForum.ImprovedTouring.com/wink.gif
if you use a nylon strap ...tie wrap it up off frame and ground then duck tape it to stiffen and make easier access
ISC Racing in Winter Haven, FL has a short (approx.6"), heavy duty nylon strap with a 2" I.D. ring on one end and a metal seat belt tie down on the other end to bolt or weld to the frame. You can use a tie wrap to keep it from swinging or dangling. I heard that some tracks are measuring the diameter to comply with the 2" I.D. and I was told that the 1.5" x 3" links that I've had sticking out of my front bumper and dangling from my rear frame for years do not meet the 2" I.D. requirement. Intent and the 3" direction weren't enough. I'm getting two of ISC's set up. (863)324-4539.
