Originally posted by Banzai240:
Are we talking about the ITS Acura Integra 3-Door GS-R with 172 stock HP?? If so, assuming a meager 25% increase with IT prep, I'd have to say that this one is SPOT ON for the class... In fact, I'm thinking it's a little on the light side, if the HP numbers work out correctly...
Compare this to the '95-'98 240SX, which has to weight 2650lbs and only makes 155hp stock, or the 944, which has 157hp stock and has to weight 2715lbs...
I'm not sure I'd be complaining if I were you...
Keep in mind that stock weights have very little to do with final weight these days... except to try to help determine if the final weight can be achieved with legal IT prep...
Looking at the numbers, the Acura being discussed looks like a really NICE choice for an ITS car...
Good Luck!
Not entirely sure where you are getting the figure 172 stock HP? Most stock numbers are about 150whp.
