I am Rex Deffenbaugh – driver first, NC Region administrator second. I became an administrator to protect my privilege to drive from errant administration meddling. Now I see another occurrence of this meddling threatening my class again.
I was at the first meeting when IT7 was proposed by Lee Graser and Stan Hines and where a vote was taken to establish IT7. I voted. I watched as administration fought the establishment of IT7 using every resource available. I watched while extensive research was executed to find the tire most likely to fulfill the need for a spec tire including tire cost, life, and track support. Then I voted. I watched as the results reflected by Scott Galimore were returned.
IT7 was started as a class of has been RX7 cars that couldn’t compete in ITA. Its inception was because some drivers wanted an inexpensive venue to compete in, in similarly prepared cars. It was to be a class where one couldn’t spend his way to a win, like many other classes then and now. It was never a class for the world’s fastest man. There are many other classes and even series for the world’s fastest man. The great thing about this country is that you have choices. Yours may be to run in one of these faster classes or series, but IT7 will never afford one the recognition the world’s fastest man deserves – only the recognition of the fastest IT7 car and driver. Some may want to set their sights higher and leave the drivers of this class to our selves. As reported by Scott Galimore, the results of a vote stated that the drivers of this class want the tire rule now in place. Every class and venue of racing has rules, and this is one for racing in IT7. If you can’t find the setup, or you think it costs too much to make your car go fast in this class then ITA may be better for you – again another great choice.
In the end none of these questions are the issue here. The issue is someone making an underhanded attempt to change a rule established by the majority of drivers in this class. Every rule will have some opposition, but in this case a small minority has the ear of an administrator who seems to have the power and willingness to slide a rule change into place without a majority vote. Toni says rules will be reviewed for change every year. This is not true because of the sheer volume of rules in place. Why did she choose this rule and not the countless others to review? She says she doesn’t have the resources or time to complete a good pole. This is understandable but not a good reason to execute an incomplete pole and change rules as a result. Administrators feign concern about falling participation in IT7, but this doesn’t hold water when ITA is almost nonexistent, except for the IT7 drivers who have defected there, and administrators don’t seem concerned about that class. The drivers of this class will not tolerate the unwanted and unneeded meddling that may jeopardize the quality of the racing now experienced in IT7.
Rex
