If you're going to make stuff up, try to be a BIT believable, Tom. Joe? In a Speedo? NObody wants to even think about that, much less see it!
Any updates on updating mylaps.com with WGI July times??? Or am I just being *special* again?
Thanks Joe...It takes one to know one.
How's living in 'Bushkill'? Get any? :)
Now on a more serious note regarding MY-laps. The current software used by the Glen region is orbitz one(?) The region would need to upgrade to orbitz 4 according to info at the meeting. Plus apparently there is another upgrade lurking in the wings and cost is significant. The other issue becomes operating the new system. I'm certain other regions have some of the same issues, since we all use volunters to man these systems sometimes have to tread lightly with changes. Perhaps a "Professional" timing group? But at what cost?? TW
__________________
I imagine there's a way to produce an electric file containing lap times. Could even be in an excel format. Put the file on the regions website, and allow people to download from there. It doesn't have to be on mylaps. Might this be possible?
Let me check. Also seems like on my laps we were able to compare our times to another competitor that function seems to have gone away?
Tom,
It is still there. You have to click on your name from the results page. Once that opens up there is a drop-down on the right, below the graph and above the chart, that lets you select another driver for comparison.
Any progress on finishing construction on I-81?
DZ
Dave, thanks for the info on mylaps. I found it! 81 Is STILL under construction north of clarks summit went to National at Pocono and cut over on turnpike at Bear creek exit and came back north to 6 and home to avoid as it was backed up for looooooooooooooong ways because of the bridge work!!
