Dear IT7 Drivers,
<span style="color:#3333FF">It has come to our attention that one of our traditional VIR vendors, Appalachian Tire, will likely not have the required IT7 Toyo spec tire available for the "Al Fairer SARRC/MARRS Challenge". Consequently, IT7 competitors should assume that these tires will not be available at the track and should bring their own adequate supply or make other arrangements to insure they have the correct tires for the event. If you do not make arrangements to bring the required tires, be prepared to participate in a different class such as ITA, which does not have a spec tire rule.
We apologize for any inconvenience caused by this and hope this notice helps you prevent an potential problems.
Ginny Condrey
North Carolina Region, SCCA</span>[color=#3366FF]
