Originally Posted by
lateapex911
There are several reasons that the writer might want different injectors....perhaps he actually is rich at certain points, lean at others, and the combination of higher pressure and smaller injectors yields more power. Or vice versa.
To your other points. Actually, you should say "Standalones have been legal for years now", assuming you are talking about ECUs. Keep in mind the Process and weighting of the cars was done post open ECU rule.
Which leads to the next point. Cars are classed based on stock hp and a process. The stock HP is made with stock injectors. To now open up injectors would change the balance that exists. Good idea? I think not.
Your RR shock comment is, to my eye, not comparable. First, there is no rule change or proposal regarding RR shocks on the table. Second, people more knowledgeable that I can tell you that RR shocks are not the savior, and won't have seconds off your lap times, no matter how bright you are, compared with monotube or twintube designs. There is a perception that they are the magic bling item that shaves seconds, but that's just it, a perception.
I disagree with the comparison in terms of degree, but mostly because any shock rule would affect all cars more or less evenly while an injector change would not. Any such change would be equivalent to a post classification competition adjustment.
