Putting asphalt down over concrete is not something new, DOT does it all the time. Most applications use a binder between coats which is a liquid that goes down, right ahead of the asphalt. This liquid acts like a glue (and is impossible to clean up once on your boots). Doesn't matter what is underneath it if the substrate is not clean and free of loose material, it would be like sticking tape on sand. Also, if the new asphalt does not achieve the correct compaction it won't hold up. It has to get rolled while its hot so it packs together, otherwise it won't be strong. I'd be more worried about this than bonding to the concrete as you'll end up w/ pot holes and washboards in the brake zones if proper compaction is not achieved.
The fact that they aren't milling it may not eliminate that whoop-di-do in the middle of turn 9. But I won't miss that transistion onto the concrete at the turn in for 5 or that crap peeling apart in the carosel. Either way, spending money like that is a show of commitment that they have no plans to change what the track is used for, ie its not headed for sub-division.
Matt
