Calling all 1996-1997 owners and all competitors interested in increased parity: Please review the letter written to the CRB below. If you agree with it, please write your own to the CRB in support of the 96-97 cars sharing the same restrictor as the 94-95 model. This was emailed to
[email protected] today:
CRB:
Thank you for your service to the club, and particularly Spec Miata.
Please review competition results and the rules that restrict airflow in the 1996 and 1997 Spec Miata. When compared with the 1994-1995 Miata, less airflow is allowed at the throttle body for the 1996 and 1997 models which has a dramatic effect on their power curves and is inconsistent with GCR rules that otherwise equalize the 94-95 to the later models.
The later models (96-97) should be allowed to run the same restrictor as the 94-95 models to make them competitive. The proof is in the competition results, but the technical reason lies in the fact that the 96-97 share the SAME computer as 1995 models build after March 1995. Further, the 94-95 originally had lower compression than the late 95, and 96-97 cars. Since 9.0:1 compression is allowed per the GCR and factory specs, 94-95 cars can be brought up to the 96-97 specification, legally.
Specifically:
Starting with the 3/95 start of the ODB-II implementation (VIN 14193) the pistons were changed with a slight dome to increase the compression ratio to an actual 9.0:1. The '94-3/95 pistons were factory rated at 9.0:1 but actually was around 8.8.
I own both a 1996 and an early 1995 car (pre-computer change/compression increase). Both have been dyno'd extensively with several engines. Mazdaspeed supplies the same crate engine to all cars from 1994-1997. The 1996 consistently lags in power to the 94 and 95 cars by approximately 2-3 horsepower, presumably because of the smaller restricted inlet. Most 94-95 cars in SM have been legally modified, or have replaced motors, to meet the factory (and GCR) specification for 9.0 compression, so true differences between the engines 94-97 do not exist.
Please allow the 96-97 Spec Miata to share the 47 mm restrictor with the 94-95 cars, as the current 45 mm restrictor is unfair due to GCR allowed compression increases in the 94-95 and fact that 95-97 cars share ODB-II computers (the 94 ODB-I computer is not slouch either).
Thank you for considering these changes.
