Good to see anothers view... Just wondering what this is you are talking about on the Audi???Quote:
Did any one say that green cap thing on the 5th gear end of the tranny? i lost one in topika. cant turn right any more.
I think you might be wrong on that one... check it out if you have an Audi, I thought all the '80's 2.2L front ends were basically the same, Quattro or not.Quote:
You have a GT so you only need one axle, L or R its the same. [/b]
Agreed on most all that stuff... The front struts are huge and bulky, but wheel bearing failures are an issue... so unless you can change one at the track you may want to bring a "loaded" strut housing with a whellbearing in it.Quote:
shifter parts seam to be the biggest prob with an audi. One control arm there the same L or R (all the same on a 4000Q) the front struts are HUGE and bulky, rear panhard bar, Pre fuel pump filter
Not sure that these would fail at the track sidelining you...Quote:
timing belt tentioner OR water pump, cam seals, INTAKE BOOT,
Raymond "Just my thoughts from experience, not trying to be critical" Blethen
