I'm pretty sure the VIN# requirement is in the ITCS. No reason for it to be int eh GCR, as it is a category-specific issue.Quote:
Originally posted by 88YB1@Oct 31 2005, 05:10 PM
Very interesting. I drive a Pontiac Fiero. The GCR spec line lists both the Formula and GT models for 1988. They have a different code in the vin, and the Formula is about 200 lb lighter. Since there is only one spec line in the ITCS does that mean I could put the fastback GT body panels on my Formula? ITCS trumps the GCR, and the vin statement being discussed is in the GCR. Just asking. Would make no sence doing this B) , but going the other way would be an advantage for the GT. Remove 200 lbs from the rear, then ballast back to minimum with weight up front.
Chuck
[snapback]64116[/snapback]
