A GM MAP sensor (which most standalone systems use) has a three pin connector. +5V, GRN, and signal. The GRN and +5V are easy to source. You could easily use one of the connectors for any emissions related item that is not being used (the vacuum rats nest comes to mind) connected to the signal output of the sensor to route the signal back to the box and then reconfigure the wiring inside the box to get the signal to your EMS of choice. Come on Marty, gotta think outside the box. http://Forum.ImprovedTouring.com/it/wink.gif
Mazda actually uses a MAP sensor in the stock system too. It's the "boost sensor". It's mounted on the right hand wheel well.
Chris Ludwig
08 ITS RX7 CenDiv
